Introduction
This guide will show how the logic board for the IBM WorkPad c3 may be removed. This is a fairly simple process, once the rest of the WorkPad has been disassembled.
Using a hair dryer, slowly heat the edges of the WorkPad.
Spend at least one minute heating each side of the device. This will melt the glue holding the case together, and allow it to be removed.
If the back case has already been removed, carefully place it on the WorkPad to protect the circuitry inside from the heat.
Using the hair dryer, slowly heat the edges of the device. Spend at least 1 minute on each side, thoroughly heating the case.
Using the Plastic Opening Tools, take the front of the case off.
The power button at the top of the device will be loose once the front part of the case is removed.
Using your thumb, press down gently on the back of the LCD.
The LCD will disconnect and fall out of the case, so be sure to have your hand waiting for it.
