Repairing IBM ThinkPad T42 Speakers
  1. Repairing IBM ThinkPad T42 Speakers, Bottom cover: step 1, image 1 of 1
    • Using a Phillips #0 screwdriver, identify and unscrew the twenty screws located on the underside of the T42.
  2. Repairing IBM ThinkPad T42 Speakers, Rear screws: step 2, image 1 of 1
    • Unscrew the four Phillips screws located on either side of the rear of the T42 (there are two located on each end.)
  3. Repairing IBM ThinkPad T42 Speakers, Keyboard and Trackpad: step 3, image 1 of 1
    • Flip the laptop over and open the screen to access the keyboard and trackpad.
    • The keyboard and trackpad are connected to the motherboard. Before removing the keyboard and trackpad, disconnect both components from the motherboard, as shown in the following step.
    • The bezel and keyboard will be loose, be careful.
  4. Repairing IBM ThinkPad T42 Speakers: step 4, image 1 of 2 Repairing IBM ThinkPad T42 Speakers: step 4, image 2 of 2
    • Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
    • Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
  5. Repairing IBM ThinkPad T42 Speakers, Lower Bracket: step 5, image 1 of 2 Repairing IBM ThinkPad T42 Speakers, Lower Bracket: step 5, image 2 of 2
    • Grasp the metal bracket to remove it from the device.
  6. Repairing IBM ThinkPad T42 Speakers, Microphone cover: step 6, image 1 of 1
    • Remove the rubber cover from the microphone.
  7. Repairing IBM ThinkPad T42 Speakers, Speakers: step 7, image 1 of 1
    • This component is free to move.
  8. Repairing IBM ThinkPad T42 Speakers: step 8, image 1 of 1
    • Disconnect its connector and pull it out carefully.
Gerald Watanabe
279 Reputation
7 Guides authored
Cal Poly, Team 29-76, Johann Spring 2010 Member of Cal Poly, Team 29-76, Johann Spring 2010
CPSU-JOHANN-S10S29G76
4 Members
35 Guides authored
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 18
All Time: 5,299
