IBM ThinkPad T42 Keyboard and Trackpad Replacement
  1. IBM ThinkPad T42 Keyboard and Trackpad Replacement, Bottom cover: step 1, image 1 of 1
    • Using a Phillips #0 screwdriver, identify and unscrew the twenty screws located on the underside of the T42.
  2. IBM ThinkPad T42 Keyboard and Trackpad Replacement, Rear screws: step 2, image 1 of 1
    • Unscrew the four Phillips screws located on either side of the rear of the T42 (there are two located on each end.)
  3. IBM ThinkPad T42 Keyboard and Trackpad Replacement, Keyboard/Trackpad Removal: step 3, image 1 of 1
    • Flip the laptop over and open the screen.
    • The bezel and keyboard will be loose, be careful.
  4. IBM ThinkPad T42 Keyboard and Trackpad Replacement, Disconnecting Ribbon Cables: step 4, image 1 of 2 IBM ThinkPad T42 Keyboard and Trackpad Replacement, Disconnecting Ribbon Cables: step 4, image 2 of 2
    • Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
    • Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
Austin Kidd
317 Reputation
3 Guides authored
Cal Poly, Team 29-76, Johann Spring 2010 Member of Cal Poly, Team 29-76, Johann Spring 2010
CPSU-JOHANN-S10S29G76
4 Members
35 Guides authored
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 39
All Time: 10,050
