Repairing IBM ThinkPad T42 Fan
  1. Repairing IBM ThinkPad T42 Fan, Bottom cover: step 1, image 1 of 1
    • Using a Phillips #0 screwdriver, identify and unscrew the twenty screws located on the underside of the T42.
  2. Repairing IBM ThinkPad T42 Fan, Rear screws: step 2, image 1 of 1
    • Unscrew the four Phillips screws located on either side of the rear of the T42 (there are two located on each end.)
  3. Repairing IBM ThinkPad T42 Fan, Keyboard and Trackpad: step 3, image 1 of 1
    • Flip the laptop over and open the screen to access the keyboard and trackpad.
    • The keyboard and trackpad are connected to the motherboard. Before removing the keyboard and trackpad, disconnect both components from the motherboard, as shown in the following step.
    • The bezel and keyboard will be loose, be careful.
  4. Repairing IBM ThinkPad T42 Fan: step 4, image 1 of 2 Repairing IBM ThinkPad T42 Fan: step 4, image 2 of 2
    • Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
    • Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
  5. Repairing IBM ThinkPad T42 Fan, Plastic Edge Cover: step 5, image 1 of 2 Repairing IBM ThinkPad T42 Fan, Plastic Edge Cover: step 5, image 2 of 2
    • Starting from the bottom right, carefully pry off the bezel. Use a spudger or flathead screwdriver if assistance is needed.
  6. Repairing IBM ThinkPad T42 Fan, Lower Bracket: step 6, image 1 of 2 Repairing IBM ThinkPad T42 Fan, Lower Bracket: step 6, image 2 of 2
    • Grasp the metal bracket to remove it from the device.
  7. Repairing IBM ThinkPad T42 Fan, Microphone cover: step 7, image 1 of 1
    • Remove the rubber cover from the microphone.
  8. Repairing IBM ThinkPad T42 Fan, Fan: step 8, image 1 of 2 Repairing IBM ThinkPad T42 Fan, Fan: step 8, image 2 of 2
    • Unscrew the three shown screws (red), then unplug its connection with the motherboard (blue).
    • **Since both the processor and graphics processor unit are attached to this fan with thermal paste, removing the fan might require some force and a flathead screwdriver to separate the paste from the fan.
Kevin Rehm
472 Reputation
4 Guides authored
Cal Poly, Team 29-76, Johann Spring 2010 Member of Cal Poly, Team 29-76, Johann Spring 2010
CPSU-JOHANN-S10S29G76
4 Members
35 Guides authored
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 47
All Time: 26,287
