IBM ThinkPad T41 Trackpad Replacement
  1. IBM ThinkPad T41 Trackpad Replacement, Keyboard: step 1, image 1 of 1
    • Close the screen and turn the closed laptop over.
    • Remove all 17 screws on the bottom of the computer.
    • The multiple colors (turquoise, red, blue, orange, yellow, and purple) are for organizational purposes, indicating different screws.
    • The yellow marker at the rear denotes the UltraBay device retaining screw. This screw is optional as the UltraBay mechanism will hold the drive or battery in place anyway. The yellow marker at the front denotes the hard disk caddy retaining screw.
  2. IBM ThinkPad T41 Trackpad Replacement: step 2, image 1 of 1
    • Remove the extra RAM cover, by lifting where the screw was and pulling out.
  3. IBM ThinkPad T41 Trackpad Replacement: step 3, image 1 of 1
    • Turn the laptop right side up and open the screen.
    • Lift the keyboard, using a spudger at the seam between the keyboard and trackpad.
    • Careful of the ribbon cable underneath, which may tear if the keyboard is lifted too vigorously.
  4. IBM ThinkPad T41 Trackpad Replacement: step 4, image 1 of 1
    • Unplug the keyboard’s ribbon cable, by lifting up the edges of the plug.
    • Remove the keyboard.
  5. IBM ThinkPad T41 Trackpad Replacement, Trackpad: step 5, image 1 of 1
    • Close the laptop and turn it over.
    • Remove the five plastic stickers covering the screws on the front edge of the case.
    • In order to reuse the stickers, remove them carefully.
  6. IBM ThinkPad T41 Trackpad Replacement: step 6, image 1 of 1
    • Unscrew the five screws that were hidden by the stickers.
  7. IBM ThinkPad T41 Trackpad Replacement: step 7, image 1 of 1
    • Turn the computer right side up and open the screen.
    • Lift the trackpad assembly by placing hands on both edges and then pull towards you till it is free of the case.
    • Careful of the ribbon cable underneath, which may tear if trackpad is pulled too vigorously.
  8. IBM ThinkPad T41 Trackpad Replacement: step 8, image 1 of 1
    • Unplug the trackpad’s ribbon cable by pulling on the white plastic tab.
Marissa Blustein
501 Reputation
12 Guides authored
Cal Poly, Team 7-8, Maness Spring 2010 Member of Cal Poly, Team 7-8, Maness Spring 2010
CPSU-MANESS-S10S7G8
4 Members
26 Guides authored
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 14
All Time: 4,578
