Repairing IBM ThinkPad T41 Speakers
  1. Repairing IBM ThinkPad T41 Speakers, Keyboard: step 1, image 1 of 1
    • Close the screen and turn the closed laptop over.
    • Remove all 17 screws on the bottom of the computer.
    • The multiple colors (turquoise, red, blue, orange, yellow, and purple) are for organizational purposes, indicating different screws.
    • The yellow marker at the rear denotes the UltraBay device retaining screw. This screw is optional as the UltraBay mechanism will hold the drive or battery in place anyway. The yellow marker at the front denotes the hard disk caddy retaining screw.
  2. Repairing IBM ThinkPad T41 Speakers: step 2, image 1 of 1
    • Remove the extra RAM cover, by lifting where the screw was and pulling out.
  3. Repairing IBM ThinkPad T41 Speakers: step 3, image 1 of 1
    • Turn the laptop right side up and open the screen.
    • Lift the keyboard, using a spudger at the seam between the keyboard and trackpad.
    • Careful of the ribbon cable underneath, which may tear if the keyboard is lifted too vigorously.
  4. Repairing IBM ThinkPad T41 Speakers: step 4, image 1 of 1
    • Unplug the keyboard’s ribbon cable, by lifting up the edges of the plug.
    • Remove the keyboard.
  5. Repairing IBM ThinkPad T41 Speakers, Trackpad: step 5, image 1 of 1
    • Close the laptop and turn it over.
    • Remove the five plastic stickers covering the screws on the front edge of the case.
    • In order to reuse the stickers, remove them carefully.
  6. Repairing IBM ThinkPad T41 Speakers: step 6, image 1 of 1
    • Unscrew the five screws that were hidden by the stickers.
  7. Repairing IBM ThinkPad T41 Speakers: step 7, image 1 of 1
    • Turn the computer right side up and open the screen.
    • Lift the trackpad assembly by placing hands on both edges and then pull towards you till it is free of the case.
    • Be careful of the ribbon cable underneath. It may tear if the trackpad is pulled too vigorously.
  8. Repairing IBM ThinkPad T41 Speakers: step 8, image 1 of 1
    • Unplug the trackpad’s ribbon cable by pulling on the white plastic tab.
  9. Repairing IBM ThinkPad T41 Speakers, RAM: step 9, image 1 of 1
    • Push apart the retaining clips on the RAM.
    • Note: The RAM should pop up a little bit.
  10. Repairing IBM ThinkPad T41 Speakers: step 10, image 1 of 1
    • Lift out the RAM chip.
  11. Repairing IBM ThinkPad T41 Speakers, Wireless Network Card: step 11, image 1 of 1
    • Pull off the one black and one white coaxial cables by lifting the tabs labeled main and aux (for auxiliary).
  12. Repairing IBM ThinkPad T41 Speakers: step 12, image 1 of 1
    • Push apart the retaining clips.
    • Note: The card should pop up a little bit.
  13. Repairing IBM ThinkPad T41 Speakers: step 13, image 1 of 1
    • Pull the wireless network card out.
  14. Repairing IBM ThinkPad T41 Speakers, CMOS Battery: step 14, image 1 of 1
    • Lift the yellow plastic-covered battery up.
  15. Repairing IBM ThinkPad T41 Speakers: step 15, image 1 of 1
    • Unplug the battery connector.
  16. Repairing IBM ThinkPad T41 Speakers, Speakers: step 16, image 1 of 1
    • Lift the speakers out by starting with the left end and then unsnake the wires.
  17. Repairing IBM ThinkPad T41 Speakers: step 17, image 1 of 1
    • Unplug the wires from the motherboard.
Marissa Blustein
501 Reputation
12 Guides authored
Cal Poly, Team 7-8, Maness Spring 2010 Member of Cal Poly, Team 7-8, Maness Spring 2010
CPSU-MANESS-S10S7G8
4 Members
26 Guides authored
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 12
All Time: 12,462
