Introduction
This repair guide will aid you in taking apart your IBM ThinkPad T41 laptop to reach and replace its motherboard.
Close the screen and turn the closed laptop over.
Remove all 17 screws on the bottom of the computer.
The yellow marker at the rear denotes the UltraBay device retaining screw. This screw is optional as the UltraBay mechanism will hold the drive or battery in place anyway. The yellow marker at the front denotes the hard disk caddy retaining screw.
Close the laptop and turn it over.
Remove the five plastic stickers covering the screws on the front edge of the case.
Pull off the one black and one white coaxial cables by lifting the tabs labeled main and aux (for auxiliary).
Lift the speakers out by starting with the left end and then unsnake the wires.
Remove the screw on the left hand side of the case, above the expansion slot.
Lift the black plastic border by lifting on either side.
Once the sides are up, pull the border towards you and away from the screen.
When lifting up, there are two pairs of plastic clips hooking into the fan grill. If you pull hard enough the border will come away, but it's better to push the clips with the spudger.
Remove the three screws holding down the modem in the upper left corner of the laptop.
Close the computer screen.
Remove the four screws on the back of the laptop, near the right and left hinges.
Remove three screws near the edge of the computer, holding the optical bay and HDD covers.
Remove three other screws on the other side of the covers.
Lift the fan out.
why do you need to remove the CPU chip, the RAM and wireless card? Seems to me those could stay there.....
Turn the CPU retaining screw 90 degrees counterclockwise.
Carefully pull the CPU out of its socket.
Remove the two screws in the upper right corner that secure the gray metal frame.
20 other people completed this guide.
6 Comments
Hello,
Thanks for this !
When assembling again, I noticed that at the contact between the micro-processor and the cooler the thermal paste there was a very small amount of thermal paste.
I had none to add, therefore I reassembled as is.
After starting the machine again I note that the cooling fan never stops.
I suggest that at reassembling should thermal paste added.
ibm thinkpad t42 laptop driver are not download please sir my laptop motherboard information send in my email id . how can download driver download for ibm laptop
Excellent tutorial. Thank you.
thanks alot!
It’s tempting to try, but I’d feel much braver with a reassembly tutorial!
Is it a mistake to turn the CPU lock 180 degrees instead of 90? Can it happen that the screen stays dark if the CPU isn’t seated firmly and locked in the correct way?
You need to remove the battery, hard drive, and UltraDrive before starting step 1.
cak - Reply
