IBM ThinkPad T30 RAM Replacement
  1. IBM ThinkPad T30 RAM Replacement, Battery: step 1, image 1 of 3 IBM ThinkPad T30 RAM Replacement, Battery: step 1, image 2 of 3 IBM ThinkPad T30 RAM Replacement, Battery: step 1, image 3 of 3
    • Make sure the ThinkPad is off and the power supply is unplugged.
    • Flip the ThinkPad upside down with the bottom facing you.
    • Slide the latch to the right into the unlock position.
    • While holding the latch in the unlock position, lift the battery out with your other hand.
  2. IBM ThinkPad T30 RAM Replacement, RAM: step 2, image 1 of 2 IBM ThinkPad T30 RAM Replacement, RAM: step 2, image 2 of 2
    • Remove the 4 mm Phillips #0 screw located on the panel on the bottom right of the ThinkPad.
    • Lift up the cover and set it aside.
  3. IBM ThinkPad T30 RAM Replacement: step 3, image 1 of 2 IBM ThinkPad T30 RAM Replacement: step 3, image 2 of 2
    • Locate the four white tabs. There are two sets of white tabs, the top two holding the first RAM stick and the bottom holding the second RAM stick.
    • Removing one set at a time, press down on the white tabs at the same time. The RAM stick will pop out of place.
  4. IBM ThinkPad T30 RAM Replacement: step 4, image 1 of 2 IBM ThinkPad T30 RAM Replacement: step 4, image 2 of 2
    • Lift out the two RAM sticks.
Allie Knauer
90 Reputation
3 Guides authored
Cal Poly, Team 3-20, Amido Fall 2012 Member of Cal Poly, Team 3-20, Amido Fall 2012
CPSU-AMIDO-F12S3G20
3 Members
16 Guides authored
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 21
All Time: 3,514
