How to re-key Kwikset Key-In-Knob Lockset
    1. How to re-key Kwikset Key-In-Knob Lockset, How to re-key Kwikset Key-In-Knob Lockset: step 1, image 1 of 1
      • Start by removing the lockset from the door, or packaging. Separate and set aside the interior half of the lockset.
      • Hold the lock so that the side with the keyway is facing directly away from you.
      • Locate the driver bar on the back of the exterior, or keyed, half of the lockset. It is the long cylindrical post that protrudes from the back of the lock and is hollow on the end.
      • Insert the cylinder removal tool into the end of the driver bar and turn until the tab (circled red) is in the twelve 'o clock position.
      Ask FixBot
    2. How to re-key Kwikset Key-In-Knob Lockset: step 2, image 1 of 1
      • Turn the lock so that the keyway faces the ground.
      • Directly underneath the driver bar is another tab (circled red) just above one of the threaded posts.
      Ask FixBot
    3. How to re-key Kwikset Key-In-Knob Lockset: step 3, image 1 of 1
      • Using the edge of the cylinder removal tool, depress the tab from step 2 while removing the driver bar.
      • You should be able to pull the driver bar right out by hand. If it doesn't come out easily, here are a few tips:
      • Make sure the tab from step 1 is completely vertical and pointing towards one of the threaded cylinders. It can easily shift out of position, preventing removal of the driver bar.
      • Rotate the entire assembly 180 degrees so that the keyway faces the ceiling. While depressing the tab from step 2, wiggle the entire lockset. The driver bar should slide right out.
      Ask FixBot
    4. How to re-key Kwikset Key-In-Knob Lockset: step 4, image 1 of 1
      • With the driver bar removed, insert the forked end of the cylinder removal tool into the back of the lock.
      Ask FixBot
    5. How to re-key Kwikset Key-In-Knob Lockset: step 5, image 1 of 1
      • Gently pushing the end of the cylinder removal tool into the back of the lock should dislodge the cylinder from the rest of the lock.
      Ask FixBot
    6. How to re-key Kwikset Key-In-Knob Lockset: step 6, image 1 of 1
      • Use the forked end of the cylinder removal tool to remove the c-clip from the back of the plug.
      Ask FixBot
    7. How to re-key Kwikset Key-In-Knob Lockset: step 7, image 1 of 1
      • With the c-clip removed, insert the key that currently operates the lock and use it to turn the cylinder plug 90 degrees.
      • Do not pull on the key!
      • Use a plug follower to gently push the plug out of the cylinder from the back, as pictured.
      Ask FixBot
    8. How to re-key Kwikset Key-In-Knob Lockset: step 8, image 1 of 1
      • To rekey the cylinder, simply dump the bottom pins out of the plug and replace with the appropriate sized pins for the new key.
      • Although not necessary, a key gauge can make identifying the correct pins much quicker.
      • Ensure proper operation by reinserting the plug into the cylinder and rotating it to the 9 'o clock and 3 'o clock positions, taking care to make sure the plug does not accidentally come out of the cylinder.
      Ask FixBot
14 other people completed this guide.
Jerry Orr
947 Reputation
2 Guides authored
6 Guide Comments
Millions of Kwikset Smartkey Locks Vulnerable to Hacking, Say Researchers "Locks that are used in millions of homes and residential buildings worldwide and that are designed specifically to thwart hacking are easily opened with both a screwdriver and wire, two researchers say" what you recommend?
Ramon Melamed - Reply Share
Wow, I had no idea it could be so easy! Re-keying a lock used to be so intimidating and seemed like it would take a long time and be expensive. But this looks like it makes it really simple and quick! Thanks so much for sharing, I'll have to try this!
http://www.andersonlockandsafe.com/resid...
89jackmoore - Reply Share
I must say you have illuminate the complete process of Re-key. thanks for sharing this wonderful information.
Maisie Martha - Reply Share
Thanks for explaining these steps for Lock re key, I really appreciate your efforts and wish you luck for more amazing work in the future.
Sienna Miller - Reply Share
Confirmed this process works on Honeywell/Hyman Inc sold as Altas Home Security doorknobs at Menards and Lowes.
FlankSteak - Reply Share
Past 24 Hours: 11
Past 7 Days: 45
Past 30 Days: 191
All Time: 68,145
