HyperX Cloud III Connecting Cable Replacement
    1. HyperX Cloud III Connecting Cable Replacement, Ear Cushion: step 1, image 1 of 3 HyperX Cloud III Connecting Cable Replacement, Ear Cushion: step 1, image 2 of 3 HyperX Cloud III Connecting Cable Replacement, Ear Cushion: step 1, image 3 of 3
      • Pinch the side of one ear cushion with your thumb.
      • Slide it with your thumb to remove it completely from the outline.
      • Do the same on the other side of the headset if you want to replace both ear cushions.
      Ask FixBot
    1. HyperX Cloud III Connecting Cable Replacement, Connecting Cable: step 2, image 1 of 2 HyperX Cloud III Connecting Cable Replacement, Connecting Cable: step 2, image 2 of 2
      • Use a Phillips #2 screwdriver to remove the four 9.4 mm-long screws securing the speaker plate to the earphone.
      • Use your fingers to pull and remove the black speaker plate.
      Ask FixBot
    2. HyperX Cloud III Connecting Cable Replacement: step 3, image 1 of 2 HyperX Cloud III Connecting Cable Replacement: step 3, image 2 of 2
      • Use the Phillips #2 screwdriver to remove the 9.4 mm-long single screw securing the head of the connecting cable.
      Ask FixBot
    3. HyperX Cloud III Connecting Cable Replacement: step 4, image 1 of 2 HyperX Cloud III Connecting Cable Replacement: step 4, image 2 of 2
      • Use the Phillips #2 screwdriver to remove the two 6.8 mm-long screws securing the motherboard.
      Ask FixBot
    4. HyperX Cloud III Connecting Cable Replacement: step 5, image 1 of 2 HyperX Cloud III Connecting Cable Replacement: step 5, image 2 of 2
      • Use tweezers to turn the motherboard backward, to desolder the connecting cables wires on this side.
      Ask FixBot
To reassemble your device, follow the steps instructions in reverse order.
Prior knowledge of soldering is required and working with wires is necessary.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 51
Past 30 Days: 269
All Time: 884
