Hydraulic Fluid Draining
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Hydraulic Fluid Draining, Disconnect the spark plug wire: step 1, image 1 of 2 Hydraulic Fluid Draining, Disconnect the spark plug wire: step 1, image 2 of 2
      • Before you begin, ensure that the engine is powered down and cool to the touch.
      • Grab the plastic housing at the end of the spark plug wire and pull firmly to disconnect it.
      Ask FixBot
    2. Hydraulic Fluid Draining, Flip the engine switch to the off position: step 2, image 1 of 2 Hydraulic Fluid Draining, Flip the engine switch to the off position: step 2, image 2 of 2
      • Flip the red engine ON/OFF switch to the OFF position.
      Ask FixBot
    3. Hydraulic Fluid Draining, Close the fuel valve: step 3, image 1 of 2 Hydraulic Fluid Draining, Close the fuel valve: step 3, image 2 of 2
      • Flip the fuel valve lever to the OFF position.
      Ask FixBot
    4. Hydraulic Fluid Draining, Turn off the ignition: step 4, image 1 of 2 Hydraulic Fluid Draining, Turn off the ignition: step 4, image 2 of 2
      • Flip the ignition switch to the OFF position.
      • Ensure the wheel drive control lever is set to the neutral position.
      Ask FixBot
    5. Hydraulic Fluid Draining, Allow the wheels to freewheel: step 5, image 1 of 3 Hydraulic Fluid Draining, Allow the wheels to freewheel: step 5, image 2 of 3 Hydraulic Fluid Draining, Allow the wheels to freewheel: step 5, image 3 of 3
      • Pull the locking pin out and rotate it 90˚ to unlock the right wheel from the hub.
      • Repeat for the left wheel.
      Ask FixBot
    6. Hydraulic Fluid Draining, Add wheel chocks: step 6, image 1 of 1
      • Insert wheel chocks underneath each wheel to keep the device stationary during disassembly.
      Ask FixBot
    1. Hydraulic Fluid Draining, Remove the fill plug: step 7, image 1 of 1
      • Use a 14 mm hex key to remove the tank fill plug.
      Ask FixBot
    2. Hydraulic Fluid Draining, Remove the fluid: step 8, image 1 of 1
      • Use a siphon to pump out as much fluid as you're able to, totaling about 14 gallons.
      Ask FixBot
Carsten Frauenheim
171,406 Reputation
442 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 10
All Time: 91
