Huawei S10 Tablet USB Charge Port Replacement
    1. Huawei S10 Tablet  USB Charge Port Replacement, SIM & Micro SD Card removal: step 1, image 1 of 2 Huawei S10 Tablet  USB Charge Port Replacement, SIM & Micro SD Card removal: step 1, image 2 of 2
      • Open the cover and press the SIM card and Micro SD card in to release them both.
      • Remove the screw under the hinge cover.
      Ask FixBot
    2. Huawei S10 Tablet  USB Charge Port Replacement, Remove Back Cover: step 2, image 1 of 1
      • Use a prying tool to loosen the back cover from the display.
      • There are plastic clips holding the display and back cover together, but they come apart quite easily.
      Ask FixBot
    3. Huawei S10 Tablet  USB Charge Port Replacement, Remover Display Cable: step 3, image 1 of 1
      • Carefully separate the display unit from the back cover, but not too far.
      • There is a cable connecting the two together.
      • Lift the ZIF Connector and remove the Display Cable.
      • Lay the display to one side.
      Ask FixBot
    4. Huawei S10 Tablet  USB Charge Port Replacement, USB Charger Port Removal: step 4, image 1 of 2 Huawei S10 Tablet  USB Charge Port Replacement, USB Charger Port Removal: step 4, image 2 of 2
      • Flip the ZIF connector to loosen the flex cable for the USB charger port.
      • It is possible the cable is glued down, sliding a flat tip underneath should be enough to loosen it for removal.
      • Remove the two screws holding the charger port in place.
      Ask FixBot
    5. Huawei S10 Tablet  USB Charge Port Replacement, Install New Charger Port: step 5, image 1 of 2 Huawei S10 Tablet  USB Charge Port Replacement, Install New Charger Port: step 5, image 2 of 2
      • Install the new charger port, Insert the cable in the ZIF connector and test to make sure it charges. Replace the screws for the USB Board
      • Insert the display into the back cover.
      • Replace the screw by the SIM card / Micro SD card slot.
      • Completed!
      Ask FixBot
2 other people completed this guide.
Harvey
6,450 Reputation
10 Guides authored
3 Guide Comments
Is this charger available
Doyin Nwakanma - Reply Share
Charger port for Huawei s10
My s10 is not charging,if i plug it will show as if it was going to charge but it won't so what do i do in this situation
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 26
All Time: 3,579
