Introduction
Use this guide to replace the front camera in your Huawei P9 Lite.
Use an opening pick to unclip the rear cover, starting from the bottom corner.
Work your way around counterclockwise and carefully pry the plastic tabs open one by one.
Use a spudger to disconnect the fingerprint sensor from the motherboard.
Peel the NFC antenna cable off of the metal plate.
Disconnect the front camera flex from the motherboard.
Flip the motherboard over and thread the flex cable through the opening and take the camera away.
