Huawei P9 Lite Battery Replacement
  1. Huawei P9 Lite Battery Replacement, Back Cover: step 1, image 1 of 2 Huawei P9 Lite Battery Replacement, Back Cover: step 1, image 2 of 2
    • Use an opening pick to unclip the rear cover, starting from the bottom corner.
    • Work your way around counterclockwise and carefully pry the plastic tabs open one by one.
  2. Huawei P9 Lite Battery Replacement: step 2, image 1 of 1
    • There is adhesive underneath the back cover that holds it to the battery and the metal plate at the top.
    • Be careful with the flex cable at the right hand side.
    • Twist the opening pick to lever the back cover away and loosen it from the adhesive.
  3. Huawei P9 Lite Battery Replacement: step 3, image 1 of 1
    • When the back cover is freed from the adhesive you can pop it off by hand completely.
  4. Huawei P9 Lite Battery Replacement, Loudspeaker: step 4, image 1 of 3 Huawei P9 Lite Battery Replacement, Loudspeaker: step 4, image 2 of 3 Huawei P9 Lite Battery Replacement, Loudspeaker: step 4, image 3 of 3
    • On the bottom of the phone remove the following screws:
    • Three 2.9 mm Phillips #00 screws
    • Four 3.8 mm Phillips #00 screws
    • Now you can grab the loudspeaker unit and take it out.
  5. Huawei P9 Lite Battery Replacement, Motherboard Shield: step 5, image 1 of 1
    • Remove the nine Phillips #00 screws that secure the metal shield plate.
    • Some screws may be covered with tamper proof stickers. Remove them to ensure a proper seating for your driver.
  6. Huawei P9 Lite Battery Replacement: step 6, image 1 of 2 Huawei P9 Lite Battery Replacement: step 6, image 2 of 2
    • Do not remove the shield plate yet, it is attached by a connector and an adhered cable.
    • Use a spudger to disconnect the fingerprint sensor from the motherboard.
    • Peel the NFC antenna cable off of the metal plate.
  7. Huawei P9 Lite Battery Replacement, Battery: step 7, image 1 of 3 Huawei P9 Lite Battery Replacement, Battery: step 7, image 2 of 3 Huawei P9 Lite Battery Replacement, Battery: step 7, image 3 of 3
    • Disconnect the motherboard flex cable on both ends and take it away.
  8. Huawei P9 Lite Battery Replacement: step 8, image 1 of 2 Huawei P9 Lite Battery Replacement: step 8, image 2 of 2
    • Peel off the NFC antenna from the battery.
    • Be careful not to rip or crease the antenna.
    • If you are just removing the battery to get to the display, you can leave the NFC on the battery.
    • Unplug the battery connector.
  9. Huawei P9 Lite Battery Replacement: step 9, image 1 of 3 Huawei P9 Lite Battery Replacement: step 9, image 2 of 3 Huawei P9 Lite Battery Replacement: step 9, image 3 of 3
    Tool used on this step:
    Tesa 61395 Tape
    $5.99
    Buy
    • Slide the spudger under the battery at the place shown in the picture and pry it loose slowly .
    • Be careful not to damage the display flex cable that runs underneath the battery in the center.
    • When reassembling your phone replace old adhesive with double-sided tape or pre-cut adhesive strips.
Tobias Isakeit
118,436 Reputation
189 Guides authored
Past 24 Hours: 8
Past 7 Days: 53
Past 30 Days: 224
All Time: 132,373
