Introduction
A short guide on how to convert the inner workings, i.e. main circuit board and charging board, into a display unit with frame and battery. The tricky steps are captured in pictures and give an overview of what needs to be considered.
The PSmart z 2019. In contrast to its brothers, the PSmart 2019 and PSmart 2019 Plus, which are in roughly the same price range, a different approach must be observed here.
Unlike the 2019 model PSmart, we approach it from behind again and, after removing the Sim slot, place the PSmart Z on the heat plate to soften the glue.
After about 5 minutes you should be able to start. Equipped with a suction cup, a pleg and a spudger, we begin by placing the suction cup on the bottom of the back cover and lifting the back cover so far that we can easily insert the pick.
Depending on the difficulty and time, the opener should be pulled all the way along along the frame and reheated from time to time. See image.
In the direction of the camera, after it is loosened, carefully fold it over like a book and use the plastic spudger to remove the finger sensor connector from the circuit board. See picture 2 and 3
Now it's time to remove the screws.
To do this, it is best to have a small magnet mat ready to remove the screws as you take them out. Used for caution when assembling.
So first loosen all the screws and, above all, very importantly, first lift the cover of the battery connector and disconnect the cable from the circuit board. Once the screws have been loosened and removed, use the spudger to carefully separate all contacts from the circuit board.
Particular care must be taken with the screws that connect the pop-up camera to the motor and the frame
Now let's take a look at the display unit and first remove all the adhesive strips that are on it and serve as protection.
First things first, let's take the final piece from the last step and place it on the case. So the pop-up camera motor and camera are first screwed to the new frame. Don't forget the cover of the popup vam and especially the stopper of the camera. See picture 2.
If the cam is installed, the circuit board and the main camera are inserted. The first part of the assembly is done by screwing it to the frame at the respective points.
The lower part, the charging circuit board and the speaker Mic. The unit is carefully levered out of the bracket with a spudger and also moved and screwed tight.
Now that all the screws have been tightened and the connectors are connected to the circuit board, we finally apply the adhesive to glue the back cover to the frame.
A functional test to see if everything is working, done.
Check the device for functionality and, above all, check whether the pop-up camera is working.
Special thanks to these translators:
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
