Huawei MateBook D 15 (2020) LCD Replacement
  1. Huawei MateBook D 15 (2020) LCD Replacement, Case removal: step 1, image 1 of 3 Huawei MateBook D 15 (2020) LCD Replacement, Case removal: step 1, image 2 of 3 Huawei MateBook D 15 (2020) LCD Replacement, Case removal: step 1, image 3 of 3
    • Remove the 10 P5 screws securing the case.
    • Use a spudger to pry the edges of the case up, releasing the plastic tabs holding the base in place.
  2. Huawei MateBook D 15 (2020) LCD Replacement, Battery removal: step 2, image 1 of 2 Huawei MateBook D 15 (2020) LCD Replacement, Battery removal: step 2, image 2 of 2
    • Remove the 3 PH00 screws holding the battery in place.
    • Slide the battery forwards and lift it from its housing.
    • Do NOT remove the battery yet, as it is still connected to the motherboard.
    • Pry the end of the battery connector from its housing.
    • Remove the battery.
    • When reassembling, remember that replacing the battery cable in its housing requires a sliding motion in the direction of the motherboard.
  3. Huawei MateBook D 15 (2020) LCD Replacement, Remove bezel: step 3, image 1 of 2 Huawei MateBook D 15 (2020) LCD Replacement, Remove bezel: step 3, image 2 of 2
    • Using a spudger or pry tool, separate the screen bezel from the case.
    • The bezel is made from thin plastic that should not have too much force exerted on it. Exercise caution during this step.
    • Separate the bezel from the hinge housing and remove it.
  4. Huawei MateBook D 15 (2020) LCD Replacement, Break LCD adhesive: step 4, image 1 of 2 Huawei MateBook D 15 (2020) LCD Replacement, Break LCD adhesive: step 4, image 2 of 2
    • Insert a pry tool onto either side of the LCD and slide downwards towards the keyboard.
    • Repeat for the opposite side once all adhesive is broken. There are no delicate cables between this LCD and the top of the laptop case.
    • Fold the LCD upwards towards the keyboard.
  5. Huawei MateBook D 15 (2020) LCD Replacement, Remove the LCD: step 5, image 1 of 2 Huawei MateBook D 15 (2020) LCD Replacement, Remove the LCD: step 5, image 2 of 2
    • Remove the piece of tape holding the LCD cable in place
    • The LCD cable has two delicate outcroppings on each side which should not be used to pull the cable backwards.
    • Pull the cable away, removing it from the LCD.
    • Remove the LCD.
    • Follow these steps in reverse order to reassemble.
3 other people completed this guide.
Pig PlayzMC
224 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 40
Past 7 Days: 139
Past 30 Days: 553
All Time: 3,098
