Fix Your Stuff
Right to Repair
Store
Introduction
Use this guide to replace the back cover of your Huawei Mate 9 smartphone.
  1. First switch off your phone and remove the SIM card tray. First switch off your phone and remove the SIM card tray.
    • First switch off your phone and remove the SIM card tray.
  2. Remove both screws on the bottom with a Torx T2 screwdriver. Use a plastic opening tool to get between the display and the case. Open the smartphone by carefully prying out the display with all the parts out of the case.
    • Remove both screws on the bottom with a Torx T2 screwdriver.
    • Use a plastic opening tool to get between the display and the case. Open the smartphone by carefully prying out the display with all the parts out of the case.
    • Don't open the phone all the way, yet. The fingerprint sensor cable is still connected to the back cover.
  3. Swing open the phone to the right side. Disconnect the fingerprint sensor cable with a spudger.
    • Swing open the phone to the right side.
    • Disconnect the fingerprint sensor cable with a spudger.
6 other people completed this guide.
Tobias Isakeit
81,202 Reputation
150 Guides authored
iFixit Member of iFixit
Community
135 Members
14,499 Guides authored
One Comment
So apparently they must have welded my phone together with some unknown super exotic alloy from another planet. After spending nearly an hour removing the 2 screws at the bottom of the phone using a borrowed IFIXIT tool kit from a friend I proceeded to destroy a guitar pick, 1 heavy duty guitar pick looking thingy, and 2 separating tools from the kit and all I’ve succeeded in doing so far was breaking the bottom of the back cover of my phone. All I wanted to do was save the 50 bucks the guy quoted me to fix the charging port but now I’m thinking that’s a pretty good deal after you add up the cost of repair parts for demolishing my phone. $28.00 for a new back cover that will take 6 weeks to get , a new digitizer has to be over a hundred bucks, and how do you put a price on the frustration this is going to be if I keep going? Do yourself a favor and have someone else work on your device while it can still be saved. These 2 suction cups seem to be stronger than me and I’m jacked!!!
Randy Simpson - Reply
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 29
All Time: 3,641
