Introduction
Use this guide to replace the charging board in your Huawei Mate 8 smartphone.
Use an iSclack or a suction handle in the bottom area of your phone to separate the display unit from the rear panel.
Use an opening pick to fully separate the clips, releasing the phone.
Open the phone like a book from the SIM tray side.
Use a spudger, to disconnect the fingerprint sensor cable.
Remove the liquid indicator sticker.
Remove the Phillips #00 screw that holds down the metal shield.
Use a spudger to remove the metal shield.
Use the flat end of a spudger to disconnect the display, daughterboard interconnect, and battery cables.
Lift the coaxial connector off of its socket to allow access to the daughterboard interconnect cable bracket.
Remove the bracket.
Remove the two #000 Phillips screws.
Disconnect the loudspeaker flex connecetor with a spudger.
Use the pointy end of a spudger to pry out the daughterboard.
Remove the daughterboard.
