Huawei Ascend G700 Battery Replacement
  1. Huawei Ascend G700 Battery Replacement, Preparation: step 1, image 1 of 2 Huawei Ascend G700 Battery Replacement, Preparation: step 1, image 2 of 2
    • Disconnect all connected devices (such as headphones and USB chargers).
    • Turn the device off.
    • Turn the device around.
  2. Huawei Ascend G700 Battery Replacement: step 2, image 1 of 1
    • On the same side as the powerbutton is a little notch. Using it you will have to carefully remove the back cover.
    • Use a small prying tool if you can't do this with your fingers.
  3. Huawei Ascend G700 Battery Replacement: step 3, image 1 of 2 Huawei Ascend G700 Battery Replacement: step 3, image 2 of 2
    • Now you can remove the battery, that has to be pryed off in the marked location.
Follow the steps in reverse order to put everything back together.
Special thanks to these translators:
de en
100%
Alex Niculescu is helping us fix the world! Want to contribute?
Start translating ›
Leonard Kesting
1,229 Reputation
9 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 19
All Time: 630
