Hp Deskjet Ink Advantage 1515 Paper feeds halfway fix. Replacement
  1. Hp Deskjet Ink Advantage 1515 Paper feeds halfway fix. Replacement, Hp Deskjet Ink Advantage 1515 Paper feeds halfway fix. Replacement: step 1, image 1 of 2 Hp Deskjet Ink Advantage 1515 Paper feeds halfway fix. Replacement, Hp Deskjet Ink Advantage 1515 Paper feeds halfway fix. Replacement: step 1, image 2 of 2
    • Disconnect the printer from power source and then open the photocopy/scanner door.
    • You will see four screws on the ends. Unsrew them with the necessary equipment.
    • Carefully lift the top of the printer. Lift he back first near the paper tray to expose the interior of the printer.
  2. Hp Deskjet Ink Advantage 1515 Paper feeds halfway fix. Replacement: step 2, image 1 of 3 Hp Deskjet Ink Advantage 1515 Paper feeds halfway fix. Replacement: step 2, image 2 of 3 Hp Deskjet Ink Advantage 1515 Paper feeds halfway fix. Replacement: step 2, image 3 of 3
    • Slowly remove the cables that are connected to the motherboard and the sensor.
    • Now remove all other cables connected to the motherboard as shown.
    • Unscrew the motherboard by removing three screws.
  3. Hp Deskjet Ink Advantage 1515 Paper feeds halfway fix. Replacement, Remove ink catridge to expose all cables.: step 3, image 1 of 3 Hp Deskjet Ink Advantage 1515 Paper feeds halfway fix. Replacement, Remove ink catridge to expose all cables.: step 3, image 2 of 3 Hp Deskjet Ink Advantage 1515 Paper feeds halfway fix. Replacement, Remove ink catridge to expose all cables.: step 3, image 3 of 3
    • Unscrew the three screws one on the upper side on the left and two that are in the middle of the catridge belt mover.
    • Remove it to expose the cables.
  4. Hp Deskjet Ink Advantage 1515 Paper feeds halfway fix. Replacement, Check for broken cables.: step 4, image 1 of 2 Hp Deskjet Ink Advantage 1515 Paper feeds halfway fix. Replacement, Check for broken cables.: step 4, image 2 of 2
    • As you can see in this case my printer has broken cables. The yellow, green and black cables are broken.
    • Replaces the cables. It is also important to check the sensor cable.
    • After replacing any broken cables, reassemble your printer starting with the printer mover rail.
    • Screw it tightly into place.
    • Screw the motherboard into place tightly.
    • Ensure everything is in place.
    • Your printer should work just fine.
2 other people completed this guide.
Samuel Githinji
128 Reputation
1 Guide authored
2 Comments
Thank you very much sir I got it .
Rao - Reply
You are much welcome. Glad to know I was able to help.
Samuel Githinji -
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 6
All Time: 3,297
