Vent/Bleed Coolant System on BMW E60/E90
Video Overview
    • Insert key in the dash or steering column.
    • With foot OFF the brake (don't want to start the car), push the start button (headlamps and interior systems come on).
    • Turn both temp dials as high as they will go and put the fan on the lowest setting.
    • Push the accelerator pedal in for ten seconds then let go - you will hear the water pump cycle on.
    • Set a timer for 12-15 minutes. In this time period, you will hear the water pump cycle on and off and coolant gurgling at the reservoir.
    • After 12-15 minutes turn the car off, remove the reservoir cap and check the fluid - it should be slightly below where you started.
    • Start your car. Watch your temperature. If the car will run without overheating you're done. If you will notice that the temperature is rising repeat these steps.
lifeoftech
187 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 13
Past 7 Days: 97
Past 30 Days: 504
All Time: 26,844
