TOSHIBA Satellite E45W-C4200X TrackPad Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
64
All Time:
742
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
With this guide, you will be able to learn how to replace your Trackpad on your Toshiba Satellite E45W-C4200X.
The trackpad is vital tool for controlling your curser on your computer.
Before using this guide, make sure to review the troubleshooting page to ensure theTrackpad will need to be replaced.
Make sure to power off your laptop completely and disconnect from any external power source prior to beginning the process.
Tools
    1. TOSHIBA Satellite E45W-C4200X TrackPad Replacement, Battery: step 1, image 1 of 2 TOSHIBA Satellite E45W-C4200X TrackPad Replacement, Battery: step 1, image 2 of 2
      • Remove the ten 1 mm screws that secure the back cover using a Phillips #1 screwdriver.
      Ask FixBot
    2. TOSHIBA Satellite E45W-C4200X TrackPad Replacement: step 2, image 1 of 2 TOSHIBA Satellite E45W-C4200X TrackPad Replacement: step 2, image 2 of 2
      • Use plastic opening tool to separate the back cover from the laptop.
      • Go slowly and be careful as the plastic can crack.
      • It is recommend that you start from a corner and run the tool along the edge.
      • Lift and remove the casing.
      Ask FixBot
    3. TOSHIBA Satellite E45W-C4200X TrackPad Replacement: step 3, image 1 of 2 TOSHIBA Satellite E45W-C4200X TrackPad Replacement: step 3, image 2 of 2
      • Gently lift the flap covering the top side of the battery.
      Ask FixBot
    4. TOSHIBA Satellite E45W-C4200X TrackPad Replacement: step 4, image 1 of 2 TOSHIBA Satellite E45W-C4200X TrackPad Replacement: step 4, image 2 of 2
      • Remove the four 0.5 mm screws that hold the battery in using the Phillips #1 screwdriver.
      Ask FixBot
    5. TOSHIBA Satellite E45W-C4200X TrackPad Replacement: step 5, image 1 of 2 TOSHIBA Satellite E45W-C4200X TrackPad Replacement: step 5, image 2 of 2
      • Unplug the battery from the motherboard.
      Ask FixBot
    6. TOSHIBA Satellite E45W-C4200X TrackPad Replacement: step 6, image 1 of 1
      • Remove the battery from the laptop.
      Ask FixBot
    1. TOSHIBA Satellite E45W-C4200X TrackPad Replacement, TrackPad: step 7, image 1 of 1
      • Use the heat gun to heat the top of the keyboard cover to loosen the adhesive.
      Ask FixBot
    2. TOSHIBA Satellite E45W-C4200X TrackPad Replacement: step 8, image 1 of 2 TOSHIBA Satellite E45W-C4200X TrackPad Replacement: step 8, image 2 of 2
      • Use the spudger to peel up the keyboard cover.
      • Use caution when removing keyboard cover.
      Ask FixBot
    3. TOSHIBA Satellite E45W-C4200X TrackPad Replacement: step 9, image 1 of 3 TOSHIBA Satellite E45W-C4200X TrackPad Replacement: step 9, image 2 of 3 TOSHIBA Satellite E45W-C4200X TrackPad Replacement: step 9, image 3 of 3
      • Use the heat gun to apply heat to the track pad and use the metal spudger to remove the track pad.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 64
All Time: 742
