How To Reset Watch Hands
  1. How To Reset Watch Hands, How To Reset Watch Hands: step 1, image 1 of 2 How To Reset Watch Hands, How To Reset Watch Hands: step 1, image 2 of 2
    • To make your watch easier to work with, start by taking off the straps.
    • Pull down the strap until the lug can be accessed.
    • Pull down on the lug and it should freely come out of place.
    • The lugs have springs in them so when removing, be careful not to let them fly out of your work space.
  2. How To Reset Watch Hands: step 2, image 1 of 3 How To Reset Watch Hands: step 2, image 2 of 3 How To Reset Watch Hands: step 2, image 3 of 3
    • Locate the divot on the underside of the watch.
    • Carefully place your thin blade in the divot and pop the buckle off of your watch.
  3. How To Reset Watch Hands: step 3, image 1 of 2 How To Reset Watch Hands: step 3, image 2 of 2
    • Use your tweezers to grab onto the plastic holder and gently pull it out.
  4. How To Reset Watch Hands: step 4, image 1 of 2 How To Reset Watch Hands: step 4, image 2 of 2
    • Apply pressure with the pointed tip instrument at the spot circled; around where the stem meets the main part of the watch.
    • While applying pressure, pull the stem out and it should freely come off.
  5. How To Reset Watch Hands: step 5, image 1 of 2 How To Reset Watch Hands: step 5, image 2 of 2
    • Gently place the tweezers underneath the hands of your watch.
    • To remove the hands, carefully pry upwards and all of the hands should pop off.
    • In order to not accidentally scratch the face of your watch, place a piece of paper under where you will be prying up the hands.
  6. How To Reset Watch Hands: step 6, image 1 of 2 How To Reset Watch Hands: step 6, image 2 of 2
    • Using your tweezers place the hour hand in the center of the watch.
    • Press down on the hand, so that the hour hand is firmly attached to the center post.
    • Align the hour hand with the 3 O'clock position on your watch.
    • Be careful handling the hands because they can be very fragile.
  7. How To Reset Watch Hands: step 7, image 1 of 2 How To Reset Watch Hands: step 7, image 2 of 2
    • Using your tweezers again, place the minute hand in the center of the face.
    • Align the minute hand with the 12 O'clock position.
    • Press down on the hand until the minute hand is firmly in place.
    • Look to make sure there is a small amount of space between the hour hand and the face, as well as between the minute hand and the face.
  8. How To Reset Watch Hands: step 8, image 1 of 1
    • Carefully pick up and place the second hand in the center of the watch.
    • Press down firmly so that the second hand stays in place.
    • The position of the second hand is not extremely important, but to get the most accuracy; place it in line with the minute hand.
Jayze Crawford
735 Reputation
1 Guide authored
Cal Poly, Team 17-2, Green Fall 2015 Member of Cal Poly, Team 17-2, Green Fall 2015
CPSU-GREEN-F15S17G2
4 Members
8 Guides authored
Past 24 Hours: 10
Past 7 Days: 85
Past 30 Days: 393
All Time: 83,148
