This version may contain incorrect edits. Switch to the latest verified snapshot.
This step is untranslated. Help translate it
Clean all the dirt on the bottom of the electric kettle.
Use a Phillips screwdriver to unscrew the 3/4 in. Phillips Truss-Head Self-Drilling Screws at the bottom of the electric kettle counterclockwise.
Remove the base of the electric kettle.
Remove the LED indicator buckled on the base.
Use long-nose pliers to clamp the connection between the electric kettle line and the old temperature controller to create a gap, and pull it off.
Use long-nose pliers to clamp the three nuts used to fix the old temperature controller, and twist them counterclockwise.
Align the socket on the bottom of the new temperature controller with the protrusion on the bottom of the electric kettle to assemble.
Use long-nose pliers to tighten the nut clockwise to fix the temperature controller.
Fasten the electric kettle circuit to the interface of the new temperature controller.
Re-buckle the removed LED indicator back to the base.
Buckle the base back to the bottom of the electric kettle.
Use a Phillips screwdriver to tighten the bottom 3/4 in. Phillips Truss-Head Self-Drilling Screws in a clockwise direction.
