How to replace the screen protector on your phone
      • Slide the phone out of its protective case.
      • Clean the case with warm water and a small amount of mild soap, then allow it to dry completely.
      Ask FixBot
      • Rub a soft pencil eraser gently across the earpiece grill to pull out packed dirt.
      • Shape the eraser tip to a point or cut it flat to reach between the mesh openings.
      • Avoid pressing hard to prevent damaging the speaker.
      Ask FixBot
      • Wipe the screen and body with a microfiber cloth lightly moistened with cleaning alcohol.
      • Work around the edges until all visible smudges disappear.
      • Use alcohol rather than window cleaner because it evaporates quickly and will not harm components.
      Ask FixBot
      • Dip a cotton swab in alcohol, press off excess, then lightly sweep around buttons, speakers, and the charging port.
      • Flatten the swab tip or use a blunted wooden toothpick to fit into narrow openings.
      • Stay shallow and avoid poking deep inside speakers or ports.
      Ask FixBot
      • Turn off fans and avoid activities that stir up lint or dust in the room.
      • Keep calm and patient; a clean environment and steady hands give the best results.
      Ask FixBot
      • Hook a fingernail under one corner of the old protector and peel it away from the display.
      Ask FixBot
      • Use the moist wipe supplied in the protector kit to thoroughly clean the display, especially around the bezels.
      Ask FixBot
      • Buff the glass with the dry wipe from the kit until all moisture is gone.
      • Follow with a high quality microfiber cloth to polish the surface without leaving lint.
      • Use only clean cloths that have not been washed with fabric softener to avoid oily residue.
      • Tilt the phone and inspect; the screen must be completely free of dust and fingerprints.
      Ask FixBot
      • Tap the supplied dust-removal sticker across the display to pick up any last specks.
      • Stick the tape on your work surface so you can reuse it if dust sneaks under the glass later.
      Ask FixBot
      • Peel the film from the side marked for the screen to reveal the adhesive surface.
      • If a speck lands on the adhesive, dab it away with the dust-removal sticker.
      Ask FixBot
      • Position the glass over the display so the cut-outs align with the camera and sensors.
      • Lower the protector slowly onto the screen.
      Ask FixBot
      • Press the center of the protector so the adhesive spreads to the edges.
      • Wrap a microfiber cloth around a finger and push any air pockets toward the sides until they disappear.
      Ask FixBot
      • Give the glass a final wipe, then snap the phone back into its clean, dry case.
      Ask FixBot
Your phone now sports a spotless, perfectly aligned screen protector, ready to guard the display against daily wear and accidental drops. Keep the dust-removal sticker handy for quick touch-ups, and enjoy a crystal-clear view.
Ula Gantar
16,636 Reputation
81 Guides authored
0 Guide Comments
Past 24 Hours: 20
Past 7 Days: 176
Past 30 Days: 674
All Time: 3,623
