How to repair the foot pedal (spring)
  1. How to repair the foot pedal (spring), Pedal Spring: step 1, image 1 of 2 How to repair the foot pedal (spring), Pedal Spring: step 1, image 2 of 2
    • Turn over the EC20.
    • Unscrew all 7 screws on the back.
  2. How to repair the foot pedal (spring): step 2, image 1 of 3 How to repair the foot pedal (spring): step 2, image 2 of 3 How to repair the foot pedal (spring): step 2, image 3 of 3
    • Put the EC20 on its side and put your thumb on the edge.
    • Place your other thumb on the jack input.
    • Pull them apart and slightly open the case.
  3. How to repair the foot pedal (spring): step 3, image 1 of 3 How to repair the foot pedal (spring): step 3, image 2 of 3 How to repair the foot pedal (spring): step 3, image 3 of 3
    • Turn the EC20 around and place your thumb on one of the knobs.
    • Place your other thumb on the bottom edge where part of the casing sticks out.
    • Pull them apart, you should now be able to open the casing completely.
  4. How to repair the foot pedal (spring): step 4, image 1 of 3 How to repair the foot pedal (spring): step 4, image 2 of 3 How to repair the foot pedal (spring): step 4, image 3 of 3
    • Push the rod out by using the screwdriver as a lever.
    • Pull out the rod with the wrench on the other side.
  5. How to repair the foot pedal (spring): step 5, image 1 of 3 How to repair the foot pedal (spring): step 5, image 2 of 3 How to repair the foot pedal (spring): step 5, image 3 of 3
    • Turn around the upper casing.
    • Grab the pedal and pull it out of the casing.
  6. How to repair the foot pedal (spring): step 6, image 1 of 3 How to repair the foot pedal (spring): step 6, image 2 of 3 How to repair the foot pedal (spring): step 6, image 3 of 3
    • Push the spring back in position on the ring.
    • Put the pedal back in the casing.
  7. How to repair the foot pedal (spring): step 7, image 1 of 1
    • Push the rod back in position.
Close the casing again and fasten the casing with the screws. You have now successfully replaced the spring!
2 other people completed this guide.
One Comment
1979 iron head sportster where does the foot pedal spring go
Betty Cox - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 1,360
