How to repaint your graphic card
    • Spray painting poses severe health risks if you don't take the correct safety measures Only paint in a well ventilated area. Always wear a gas mask to prevent breathing in the paint, and hold the paint can at a distance.
    Ask FixBot
  1. How to repaint your graphic card, Preparation: step 2, image 1 of 1
    • Remove all the accessories on your graphic card's casing(light strip, fans, fan cables)to prevent them from being damaged or covered up by the paint.
    Ask FixBot
  2. How to repaint your graphic card, Preparation: step 3, image 1 of 1
    • Use fine sand paper(800-1000 grit) to first remove the original paint from your graphic card and prepare the surface. It's fine if you don't remove all the original paint, but make sure that the surface is smooth so the paint can stick on.
    Ask FixBot
  3. How to repaint your graphic card, Painting: step 4, image 1 of 1
    • Find a well-ventilated area and put something underneath the casing to prevent getting paint on the ground. Put a box underneath the casing to make it easy to paint on the side of the card. Make sure you anchor the casing so that it doesn't wobble around.
    Ask FixBot
  4. How to repaint your graphic card, Applying the surface primer: step 5, image 1 of 1
    • Hold the nozzle down and spray a thin and even layer of surface primer paint onto the top of the graphic card, moving your arm horizontally. Avoid spraying continuously at one area and keep the can moving. Hold the can at a distance and paint only a thin layer every time.
    • Avoid applying a thick layer of paint, otherwise it might crack or bulge when drying.
    • Spray over the casing a few times until the surface primer had covered up the original color of the graphic card.
    Ask FixBot
  5. How to repaint your graphic card, Applying the surface primer: step 6, image 1 of 1
    • Apply a layer of surface primer to the sides of the casing, using the same technique as before.
    Ask FixBot
    • wait for the paint to fully dry, usually 20 minutes if you applied the paint correctly, and longer if you painted too thick.
    • It is important for the paint to dry before you proceed, so wait longer if you have to.
    Ask FixBot
  6. How to repaint your graphic card: step 8, image 1 of 2 How to repaint your graphic card: step 8, image 2 of 2
    • Flip the casing upside down and apply a layer of surface primer. If you can still see the original color of the casing at the sides, this is a good time to apply some more paint there. Tilt the can at different angles to paint at the corners.
    • This ensures that you don't see the original color when the card is assembled and mounted.
    Ask FixBot
  7. How to repaint your graphic card, Applying the second layer: step 9, image 1 of 1
    • Apply the pearl white paint on top of the graphic card, using the same techniques as before.
    • Make sure the layer is even, otherwise you might be seeing dark spots that don't reflect light.
    Ask FixBot
  8. How to repaint your graphic card, Applying the second layer: step 10, image 1 of 1
    • Paint the side of the casing with pearl white paint. Make sure that you apply paint to the corners as well.
    Ask FixBot
    • Flip the card upside down and apply a layer of pearl white paint. You can choose not to do this, as the effect isn't obvious.
    Ask FixBot
  9. How to repaint your graphic card: step 12, image 1 of 1
    • Wait 20 or more minutes for the paint to dry and reassemble your graphic card. Put it back into your computer and enjoy!
    Ask FixBot
To reassemble your device, follow these instructions in reverse order. Remember to wait for the paint to fully dry out.
Leooooo1061
2,045 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 50
All Time: 262
