Asus Eee PC 1000HA Screen Replacement
    1. Asus Eee PC 1000HA Screen Replacement, Screen: step 1, image 1 of 2 Asus Eee PC 1000HA Screen Replacement, Screen: step 1, image 2 of 2
      Tool used on this step:
      Buy
      • Remove the battery before working on your device. See this LINK for a step-by-step guide.
      • Use the metal tweezers to remove all of the rubber pads from the face of the lap top.
      • Removing the rubber pads will reveal 6 screws.
      Ask FixBot
    2. Asus Eee PC 1000HA Screen Replacement: step 2, image 1 of 1
      • Use a #00 Phillips Head screw driver to remove the 4.8mm screws.
      • There will be 6 screws total.
      Ask FixBot
    3. Asus Eee PC 1000HA Screen Replacement: step 3, image 1 of 2 Asus Eee PC 1000HA Screen Replacement: step 3, image 2 of 2
      • Use the metal spudger to pry off the outside frame of the screen.
      Ask FixBot
    4. Asus Eee PC 1000HA Screen Replacement: step 4, image 1 of 1
      • Use the #00 Phillips Head screw driver to remove the 5.44mm screws.
      • There are 6 screws total.
      Ask FixBot
    5. Asus Eee PC 1000HA Screen Replacement: step 5, image 1 of 3 Asus Eee PC 1000HA Screen Replacement: step 5, image 2 of 3 Asus Eee PC 1000HA Screen Replacement: step 5, image 3 of 3
      • Use the metal spudger to gently remove the screen from the laptop.
      Ask FixBot
    6. Asus Eee PC 1000HA Screen Replacement: step 6, image 1 of 3 Asus Eee PC 1000HA Screen Replacement: step 6, image 2 of 3 Asus Eee PC 1000HA Screen Replacement: step 6, image 3 of 3
      • Gently pull the tab that is connecting the laptop to the screen, to fully disconnect the screen from the laptop.
      Ask FixBot
Ashlee Stickle
675 Reputation
5 Guides authored
1 Guide Comment
Merci beaucoup ! Great tutorial.
Joffrey Abeilard - Reply Share
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 26
All Time: 1,801
