This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
How to make a TS jack
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
71
All Time:
409
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
Hello, today I am going to teach you how to make a TS (Tip Sleeve) jack, and for that we will need:
-a cable stripper
-solder
-a soldering iron
-wire strippers
-steel wool
    1. How to make a TS jack, The beginning: step 1, image 1 of 3 How to make a TS jack, The beginning: step 1, image 2 of 3 How to make a TS jack, The beginning: step 1, image 3 of 3
      • To begin, you must strip the cable.
      • Then, insulate the braid located around the cable and twist the braid onto itself.
      Ask FixBot
    2. How to make a TS jack, Next: step 2, image 1 of 3 How to make a TS jack, Next: step 2, image 2 of 3 How to make a TS jack, Next: step 2, image 3 of 3
      • Then, strip the red conductor to expose the center conductor.
      • Tin the braid and the conductor.
      • Then, solder the center conductor to the Tip, which is the lowest part of the jack, and solder the braid to the Sleeve of the jack.
      • And there you have it, you have made a TS jack.
      Ask FixBot
To reassemble your device, follow the instructions in reverse order.
Armel le coz
205 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 71
All Time: 409
