Difference between fake and original
  1. Difference between fake and original, Comparing controllers: step 1, image 1 of 2 Difference between fake and original, Comparing controllers: step 1, image 2 of 2
    • The black controller is an original Sony V2. The silver one is fake. The front housing looks good so far.
    • I'm showing in picture 2 only the fake one. The tiny letters XF.LIN behind the battery capacity cannot be found on the original. Same for the letters "DW" in front of the serial code. Everything else looks the same like the original.
  2. Difference between fake and original, The Screws: step 2, image 1 of 3 Difference between fake and original, The Screws: step 2, image 2 of 3 Difference between fake and original, The Screws: step 2, image 3 of 3
    • The first picture is the original. It has the original PH00 screws installed.
    • The 2nd picture displays the fake one. They used PH1 screws for this one.
    • And as you can see in the 3rd picture, the fake ones are way shorter then the original screws.
  3. Difference between fake and original, The light: step 3, image 1 of 1
    • When the controller is searching for the PS4, it should give a bright white light, not turquoise! It's obvious that the LED/Micro USB board is fake.
  4. Difference between fake and original, Battery and LED/USB board: step 4, image 1 of 3 Difference between fake and original, Battery and LED/USB board: step 4, image 2 of 3 Difference between fake and original, Battery and LED/USB board: step 4, image 3 of 3
    • Now I'll open the controller and show some more fake parts! The battery is not even close to the original one. And it's an 600mAh battery. The original delivers 800mAh. Also the fake one was telling that there was an 800mAh battery in...
    • The 2nd picture shows the original battery. Quiet a difference.
    • The 3rd picture shows the LED/Micro USB board. It's obvious fake. I do not have an picture of the original one this time. There also should be text on it like (example): JDM-011 or JDM-030. There is nothing on it here. And the text colour should be in gold not in white. You can also see the fake screw holding it together again.
  5. Difference between fake and original, Motherboard: step 5, image 1 of 3 Difference between fake and original, Motherboard: step 5, image 2 of 3 Difference between fake and original, Motherboard: step 5, image 3 of 3
    • In the 1st picture, you can clearly see a switch. The button should not be blue, but it should be white/grey.
    • You should see an motherboard name, like: JDM-040 or JDM-055. This indicated again that it's a fake.
    • 3rd picture shows the fake motherboard again (back side).
koppie007
11,788 Reputation
9 Guides authored
Protectors Of The Game Systems Member of Protectors Of The Game Systems
Community
4 Members
24 Guides authored
Past 24 Hours: 348
Past 7 Days: 2,384
Past 30 Days: 10,835
All Time: 592,596
