How to flash MNT Reform LPC firmware
    1. How to flash MNT Reform LPC firmware, Remove Bottom Plate Screws: step 1, image 1 of 1
      • Remove the following screws securing the transparent acrylic bottom plate to the main box:
      • Ten M2×6mm silver Phillips screws
      Ask FixBot
    2. How to flash MNT Reform LPC firmware, Remove Bottom Plate: step 2, image 1 of 1
      • Lift the bottom plate and set it aside.
      • Before servicing anything on the inside, make sure to remove all battery cells.
      Ask FixBot
    1. How to flash MNT Reform LPC firmware, Set LPCPROG switch to ON: step 3, image 1 of 2 How to flash MNT Reform LPC firmware, Set LPCPROG switch to ON: step 3, image 2 of 2
      • Use a spudger or your fingernail to set the DIP switch LPCP to ON.
      • The LPCP switch is located on the motherboard, between the CPU module and trackball or trackpad.
      Ask FixBot
    2. How to flash MNT Reform LPC firmware, Press LPCRESET: step 4, image 1 of 1
      • Use a spudger or your finger to press the LPCRST button next to the DIP switch from the previous step.
      Ask FixBot
    3. How to flash MNT Reform LPC firmware, Plug in a USB cable: step 5, image 1 of 1
      • Connect a Micro-USB cable into the LPC USB port.
      • On newer revisions of the Reform, the Micro-USB port has been replaced with a USB type-C port.
      Ask FixBot
    4. How to flash MNT Reform LPC firmware, Flash the LPC firmware: step 6, image 1 of 1
      • Plug the other end of the cable into another computer. The system controller's memory appears as a virtual flash drive on that computer.
      • Open a terminal and navigate to the reform2-lpc-fw folder you've downloaded from the Reform repository.
      • Check lsblk or dmesg -w to find out which drive the LPC shows up as, then edit flash.sh with the correct path to the virtual flash drive (e.g. /dev/sdx).
      • Double-check the path to make sure it is correct, as entering the wrong one could destroy data on your computer!
      • Execute flash.sh as root.
      Ask FixBot
    5. How to flash MNT Reform LPC firmware, Unplug the USB cable: step 7, image 1 of 1
      • Disconnect the USB cable from the LPC USB port.
      Ask FixBot
    6. How to flash MNT Reform LPC firmware, Set LPCPROG switch to OFF: step 8, image 1 of 2 How to flash MNT Reform LPC firmware, Set LPCPROG switch to OFF: step 8, image 2 of 2
      • Use a spudger or your fingernail to set the DIP switch LPCP to OFF, which is the side labeled "1".
      Ask FixBot
    7. How to flash MNT Reform LPC firmware, Press LPCRESET again: step 9, image 1 of 1
      • Use a spudger or your finger to press the LPCRST button again.
      Ask FixBot
To reassemble your device, follow steps 1 and 2 in reverse order. Ensure that no cables are squeezed when replacing the bottom plate. Don't overtighten screws.
Neelfyn
981 Reputation
9 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 44
All Time: 1,642
