iHome iH9 Speaker Replacement
    1. iHome iH9 Speaker Replacement, Backup Batteries: step 1, image 1 of 3 iHome iH9 Speaker Replacement, Backup Batteries: step 1, image 2 of 3 iHome iH9 Speaker Replacement, Backup Batteries: step 1, image 3 of 3
      • Pull the tab towards you and lift up to remove the battery cover.
      • Remove the two AA batteries.
      Ask FixBot
    1. iHome iH9 Speaker Replacement, Opening the iHome iH9: step 2, image 1 of 1
      • Unscrew the four 8mm Phillips #2 screws.
      • Unscrew the six 25mm Phillips #2 screws.
      • Reinstall the backup battery cover so it is out of the way.
      Ask FixBot
    2. iHome iH9 Speaker Replacement: step 3, image 1 of 3 iHome iH9 Speaker Replacement: step 3, image 2 of 3 iHome iH9 Speaker Replacement: step 3, image 3 of 3
      • Pry the backplate up with a plastic opening tool between the back plate and the speaker grill.
      • Be careful when lifting the bottom plate up; there is a short white and orange 4-pin connector attached to its underside.
      • Lift the bottom plate up while making sure the connector remains attached.
      Ask FixBot
    3. iHome iH9 Speaker Replacement: step 4, image 1 of 3 iHome iH9 Speaker Replacement: step 4, image 2 of 3 iHome iH9 Speaker Replacement: step 4, image 3 of 3
      • Use your hands to flip the backing plate away from you and rest it upside down on the iH9.
      • Unplug the white and orange 4-pin connector by pulling it in the direction of the wires.
      • Set the backing plate aside.
      Ask FixBot
    4. iHome iH9 Speaker Replacement: step 5, image 1 of 1
      • Place the device so that the speaker grill is face down.
      • Remove the two 10mm Phillips #2 screws on interior sides of the speaker housings.
      Ask FixBot
    5. iHome iH9 Speaker Replacement: step 6, image 1 of 2 iHome iH9 Speaker Replacement: step 6, image 2 of 2
      • Place the iH9 upside down.
      • Wires connect the core assembly to the housing; do not attempt to pull the core assembly completely out.
      • Using both hands, pull the housing siding away from the device while simultaneously lifting the motherboard and speaker assembly straight up.
      • Repeat for the other side.
      Ask FixBot
    6. iHome iH9 Speaker Replacement: step 7, image 1 of 1
      • Stand the iH9 on its grill.
      • Separate the motherboard and speaker assembly by rocking it back and forth and pulling the assembly towards you.
      • Remove the small back panel.
      Ask FixBot
    7. iHome iH9 Speaker Replacement: step 8, image 1 of 3 iHome iH9 Speaker Replacement: step 8, image 2 of 3 iHome iH9 Speaker Replacement: step 8, image 3 of 3
      • Firmly pull the wide 9-pin connector with black covering on the underside of the upper housing to unplug it.
      • Lay the housing and core assembly flat and close to each one another.
      Ask FixBot
    8. iHome iH9 Speaker Replacement: step 9, image 1 of 2 iHome iH9 Speaker Replacement: step 9, image 2 of 2
      • Unplug the narrow 9-pin connector from the motherboard.
      Ask FixBot
    9. iHome iH9 Speaker Replacement: step 10, image 1 of 1
      • Cut the zip tie holding the wires together with a wire cutter. The two sides of the device housing are now fully separated.
      Ask FixBot
    1. iHome iH9 Speaker Replacement, Speaker: step 11, image 1 of 1
      • Set the iHome iH9 speaker and mother board assembly upright on the speaker grill.
      • Remove the black ground wire from the grill by pulling in the direction of the wire.
      • The wire is located next to the left speaker housing.
      Ask FixBot
    2. iHome iH9 Speaker Replacement: step 12, image 1 of 1
      • Unplug the 3-pin connector for the infrared sensor by pulling in the direction of the cable.
      • The wire is near the ground wire tab.
      Ask FixBot
    3. iHome iH9 Speaker Replacement: step 13, image 1 of 2 iHome iH9 Speaker Replacement: step 13, image 2 of 2
      • Set the iH9 flat down with the solder side of the motherboard up and the speaker grill facing away.
      • With a nylon or metal spudger, pry the speaker grill up and forward from the two retaining flanges on the left and right speaker housings.
      • Set the speaker grill aside.
      Ask FixBot
    4. iHome iH9 Speaker Replacement: step 14, image 1 of 1
      • Flip the iH9 back over, exposing the motherboard components.
      • For the right speaker, unplug the speaker wire by pulling in the direction of the wire (pictured).
      • For the left speaker, unplug the speaker wire by pulling in the direction of the wire.
      Ask FixBot
    5. iHome iH9 Speaker Replacement: step 15, image 1 of 2 iHome iH9 Speaker Replacement: step 15, image 2 of 2
      • Remove the four 14mm Phillips #1 screws on each of the speaker's four corners.
      • The right speaker is pictured; the same procedure is necessary to replace the left speaker.
      • Remove the speaker.
      Ask FixBot
    6. iHome iH9 Speaker Replacement: step 16, image 1 of 1
      Ask FixBot
Curtis Wathne
397 Reputation
3 Guides authored
Cal Poly, Team 8-39, Amido Winter 2015 Member of Cal Poly, Team 8-39, Amido Winter 2015
CPSU-AMIDO-W15S8G39
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 30
Past 30 Days: 43
All Time: 971
