How to fix a printer that won't print
      • Make sure you have all the necessary tools before you start tearing apart your printer. For this example, I am going to be using an HP ENVY 110 printer. However, it should work for other printers as well. The stuff you need is listed below. Things in bold are required.
      • A screwdriver.
      • A computer.
      • Printer ink.
      • This guide (obviously)
      Ask FixBot
      • When a printer feeds paper for printing, the rollers that transport the paper can sometimes cause the paper to jam.
      • Open the ink access area using a screwdriver (or in my case, my own strength) and locate the carriage access panel (circled).
      • Remove the panel n
      Ask FixBot
Your file should print! If it doesn't, try the above steps again, or contact someone who fixes printers.
4 other people completed this guide.
Lappy4861
237 Reputation
1 Guide authored
1 Guide Comment
That's a useful starting guide. Before opening the printer or taking it apart, I'd recommend checking a few basic things since many "won't print" issues are software or connectivity related rather than hardware failures.
Make sure the printer is powered on, has no error lights, and is set as the default printer on the computer. Check the print queue for any stuck jobs and clear them if necessary. Verify that the USB or Wi-Fi connection is stable, and print a built-in self-test page directly from the printer. If the self-test prints correctly, the issue is likely with the computer, driver, or connection instead of the printer.
If the self-test also fails, inspect the ink cartridges to ensure they're properly installed and have sufficient ink. Running the printer's built-in printhead cleaning or nozzle check can often resolve blank or faded prints. Only consider opening the printer if you've ruled out these common causes and suspect a paper jam, damaged mechanism, or other internal hardware problem. This approach
hiba velmet - Reply Share
Past 24 Hours: 5
Past 7 Days: 33
Past 30 Days: 120
All Time: 1,146
