How to fix a broken infill on a ProtoCentre 999
    • Open kissliser
    • click on style
    • Decrease the infill density to a value of around 20% is normal
    • Go to the machine main menu.
    • There you can see the print speed in percentage.
    • Reduce the print speed in between a value of 50% to 100%.
    • Open kisslicer
    • Go to style
    • change the infill pattern to straight,octagonal, rounded based on the kind of print you are going on with.
    • In some case , the filament may stick on the nozzle tip and while going for the print, the filament sticked will hit the infill and cause infill to break.
    • Remove the sticked filament from the nozzle with the help of a needle tip,
abhishek j
1,169 Reputation
11 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 30
