How to fix S2 hibernation issues on a Dell Latitude E6540 (Temporary)
  1. How to fix S2 hibernation issues on a Dell Latitude E6540 (Temporary), Checking for the issue: step 1, image 1 of 3 How to fix S2 hibernation issues on a Dell Latitude E6540 (Temporary), Checking for the issue: step 1, image 2 of 3 How to fix S2 hibernation issues on a Dell Latitude E6540 (Temporary), Checking for the issue: step 1, image 3 of 3
    • This method (Event Viewer) is the most reliable way to confirm the issue is S2 sleep related. Administrator privileges are required.
    • Open up the Start menu or Start screen. Once opened, search for Event Viewer.
    • Open the Windows Logs section, and select System. You will find the log files to confirm a S2 issue here.
    • Find an entry that is related to volmgr. If you see such an entry, this is how you know the issue is S2 related.
  2. How to fix S2 hibernation issues on a Dell Latitude E6540 (Temporary), Fixing the problem: step 2, image 1 of 3 How to fix S2 hibernation issues on a Dell Latitude E6540 (Temporary), Fixing the problem: step 2, image 2 of 3 How to fix S2 hibernation issues on a Dell Latitude E6540 (Temporary), Fixing the problem: step 2, image 3 of 3
    • Open Command Prompt and search for cmd. Right click Run as administrator.
    • Enter the following commands: powercfg.exe /hibernate off and powercfg.exe /hibernate on.
    • Restart the computer to apply the change correctly. This usually works without a restart, but this will ensure it is applied.
  3. How to fix S2 hibernation issues on a Dell Latitude E6540 (Temporary), Test the fix: step 3, image 1 of 1
    • If the computer is hibernating correctly, you should see the power light remains off and the screen is black.
    • Use the computer for several hours and utilize a lot of memory.
    • Hibernate the system and see what happens. If the system hibernates without issue, the issue is resolved. If it persists, the issue is caused by another component.
Nick
88,987 Reputation
50 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,468 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 2,045
