How to fix Moulinex A15453 toaster burnt electric resistance.
  1. How to fix Moulinex A15453 toaster burnt electric resistance., Opening the toaster: step 1, image 1 of 3 How to fix Moulinex A15453 toaster burnt electric resistance., Opening the toaster: step 1, image 2 of 3 How to fix Moulinex A15453 toaster burnt electric resistance., Opening the toaster: step 1, image 3 of 3
    • First of all, get rid of the bottom cover and the plastic sides. For this you have to remove the screw covers; there are four, one in each corner, and both of the center screws.
    • After that, you have to get rid of the parts that hold the bread. They are held together by a spring at the bottom.
  2. How to fix Moulinex A15453 toaster burnt electric resistance., Access to the resistor: step 2, image 1 of 3 How to fix Moulinex A15453 toaster burnt electric resistance., Access to the resistor: step 2, image 2 of 3 How to fix Moulinex A15453 toaster burnt electric resistance., Access to the resistor: step 2, image 3 of 3
    • Next, you have to release the side clips; there are four in each side. Two of them have to be slighly turned, and the other two have to be straightened.
    • After that, you need to lift the sides from the inside.
    • Finally, the outer housing and resistor protectors should come out. Additionally, you can clean the grill and casing with some grease remover and water.
  3. How to fix Moulinex A15453 toaster burnt electric resistance., Reparing the burnt thread: step 3, image 1 of 2 How to fix Moulinex A15453 toaster burnt electric resistance., Reparing the burnt thread: step 3, image 2 of 2
    • If the burnt area is not clearly visible (for example, if it's being covered by a piece of plastic), you could use a multimeter in it's "continuity test" mode to find the faulty part.
    • Once you find the burnt zone, you have to connect the line to a adjacent area. This could be done simply by bending the thread multiple times and removing the excess.
    • Ideally, the excess thread should be removed prior the repair, to avoid it moving unintentionally and causing a electric shock.
Special thanks to these translators:
es en
100%
Cristopher Quintero is helping us fix the world! Want to contribute?
Start translating ›
Eduardo Munoz
718 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 9
Past 7 Days: 67
Past 30 Days: 250
All Time: 6,047
