Repairing Mercedes W123 Window Regulator "Screw Open" Style Motor
  1. Repairing Mercedes W123 Window Regulator "Screw Open" Style Motor, Window Regulator "Screw Open" Style Motor: step 1, image 1 of 1
    • To access and perform maintenance and repair on your power window regulator motors you will of course first need to remove the regulator. For the rear window regulators, click here to review the removal guide.
    • You will then need to remove the motor from the regulator by first removing the three 10mm bolts that attach it in place.
  2. Repairing Mercedes W123 Window Regulator "Screw Open" Style Motor: step 2, image 1 of 1
    • Before starting this guide, confirm that you are reviewing the guide for the correct motor type for your situation. This guide covers the "Screw Open" style of motor, as seen on the right. If you have a "Drill Open" style of motor as seen on the left click here to review this guide instead.
  3. Repairing Mercedes W123 Window Regulator "Screw Open" Style Motor: step 3, image 1 of 1
    • Remove the three flat-head screws on the rear cover of the gear housing.
  4. Repairing Mercedes W123 Window Regulator "Screw Open" Style Motor: step 4, image 1 of 2 Repairing Mercedes W123 Window Regulator "Screw Open" Style Motor: step 4, image 2 of 2
    • Using a flat-blade screwdriver or other appropriate tool, pry the cover off the back of the gear housing and set it aside.
    • There is a plastic gasket between the housing and the cover, so you'll want to watch for that and set it aside with the cover.
    • With the cover removed you'll see:
    • The worm gear that the electric motor turns and,
    • The main gear the turns the outer gear which then moves the regulator
  5. Repairing Mercedes W123 Window Regulator "Screw Open" Style Motor: step 5, image 1 of 1
    • Pull the black plastic electric motor cover away from the gear housing. It does not attach, it's held in place by friction, so a steady pull should move it.
  6. Repairing Mercedes W123 Window Regulator "Screw Open" Style Motor: step 6, image 1 of 2 Repairing Mercedes W123 Window Regulator "Screw Open" Style Motor: step 6, image 2 of 2
    • Place the electric motor portion of the device over a container that can catch drips as you clean it.
    • Thoroughly spray the motor with electrical cleaner.
  7. Repairing Mercedes W123 Window Regulator "Screw Open" Style Motor: step 7, image 1 of 1
    • Inspect the gears, especially the large plastic gear, for severe wear such as broken teeth. This would lead to needing a new or good used motor. If they look like the one on this motor, they can simply be re-greased.
    • This particular motor would definitely benefit from a good greasing; you can see that there is not much grease left and what is there is clumped in one area.
  8. Repairing Mercedes W123 Window Regulator "Screw Open" Style Motor: step 8, image 1 of 2 Repairing Mercedes W123 Window Regulator "Screw Open" Style Motor: step 8, image 2 of 2
    • Use a good synthetic grease, like silicone based SuperLube. Do not use petroleum based greases like vaseline or moly grease as oil based products can damage plastic and rubber parts.
    • Use your finger or, better yet, a grease syringe to thoroughly lubricate the plastic gear teeth and the worm gear.
  9. Repairing Mercedes W123 Window Regulator "Screw Open" Style Motor: step 9, image 1 of 1
    • Before re-installing the cover, apply a small amount of silicone grease to the plastic gasket to help it re-seal well.
Nicolas Siemsen
39,140 Reputation
79 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,498 Guides authored
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 38
All Time: 5,076
