How to fix Logitech Anywhere MX Phantom Double Click
    1. How to fix Logitech Anywhere MX Phantom Double Click, Front Screw Removal: step 1, image 1 of 1
      • The front screws are underneath the front gliders. The can be removed with a butterknive or Plastic Opening Tool. The gliders have three layers, be careful not to seperate them.
      Ask FixBot
    2. How to fix Logitech Anywhere MX Phantom Double Click, Removing Back Screws: step 2, image 1 of 1
      • The back screws are underneath the stickers with the battery images. You can either remove them, like I did, or just poke a hole into them to get to the screws.
      Ask FixBot
    3. How to fix Logitech Anywhere MX Phantom Double Click, Identification of the Problem: step 3, image 1 of 1
      • After the four screws are removed, the top and the bottom part can be easily taken apart. In the top part the grove that was made by the click-sensor should be cleary visible. This causes the phantom double clicks.
      Ask FixBot
    4. How to fix Logitech Anywhere MX Phantom Double Click, Solution of the Problem: step 4, image 1 of 1
      • Put a piece of tape over the groove.
      Ask FixBot
64 other people completed this guide.
Stefan Magometschnigg
1,981 Reputation
2 Guides authored
44 Guide Comments
Worked well for me, lets see how long it'll last.
Wynadorn - Reply Share
Worked for me too...saved a great little mouse!
jcrhino - Reply Share
Thank you for this hint! It worked perfectly
Wojciech Gradkowski - Reply Share
Thank you, it worked!
Jakab Ponoczky - Reply Share
Thank you for this guide! Got my mouse working and saved me some money :)
Kon-Kon Chao - Reply Share
Past 24 Hours: 6
Past 7 Days: 62
Past 30 Days: 189
All Time: 52,295
