HP Color LaserJet 2600n Fading Color Fix
  1. HP Color LaserJet 2600n Fading Color Fix, HP Color LaserJet 2600n Fading Color Fix: step 1, image 1 of 1
    • Before we begin, make sure to unplug the printer and any connected wires. To be extra safe, turn the power switch to 'off.'
    • First, let's establish what part of the printer is what so that we can communicate clearly throughout the guide. The red square is the front and the orange square is the top. After those, we have left (yellow), and right (green). The back is opposite the front and the bottom is opposite the top.
  2. HP Color LaserJet 2600n Fading Color Fix: step 2, image 1 of 3 HP Color LaserJet 2600n Fading Color Fix: step 2, image 2 of 3 HP Color LaserJet 2600n Fading Color Fix: step 2, image 3 of 3
    • Laser printers often have loose toner, a very fine and vibrant powder that will invade everything you don't want it to. I did my disassembly outside
    • Open the front door and remove the toner cartridges.
    • Set the cartridges aside for later. To keep them clean, place them in a bag or closed box.
  3. HP Color LaserJet 2600n Fading Color Fix: step 3, image 1 of 2 HP Color LaserJet 2600n Fading Color Fix: step 3, image 2 of 2
    • Place the printer so that the right side is on the ground.
    • Remove the paper tray from the bottom of the printer.
  4. HP Color LaserJet 2600n Fading Color Fix: step 4, image 1 of 1
    • Remove the indicated Phillips M3 screw from the left side of the printer
    • In this photo, the paper tray is still in the printer. On your device, the tray should already be set aside.
  5. HP Color LaserJet 2600n Fading Color Fix: step 5, image 1 of 2 HP Color LaserJet 2600n Fading Color Fix: step 5, image 2 of 2
    • Release the tabs as indicated in the example by lifting or pressing them as needed.
    • Some of the press tabs are hard to reach with a finger. If needed, gently press in the tab with a screwdriver until it releases.
  6. HP Color LaserJet 2600n Fading Color Fix: step 6, image 1 of 2 HP Color LaserJet 2600n Fading Color Fix: step 6, image 2 of 2
    • Lift and remove the left base cover
    • If it feels like something is holding the cover in place, there probably is. Go back and look for additional tabs, as I may have missed listing some of them. This applies to any item removal in this guide.
  7. HP Color LaserJet 2600n Fading Color Fix: step 7, image 1 of 1
    • Release the tab fasteners on the left side cover
  8. HP Color LaserJet 2600n Fading Color Fix: step 8, image 1 of 3 HP Color LaserJet 2600n Fading Color Fix: step 8, image 2 of 3 HP Color LaserJet 2600n Fading Color Fix: step 8, image 3 of 3
    • Lift and remove the left cover
    • When reassembling, you have to mate the three noted tabs/slots, even though they do not snap in place.
  9. HP Color LaserJet 2600n Fading Color Fix: step 9, image 1 of 1
    • Rotate the device so it rests on its back.
    • Unscrew and remove the two Phillips M3 screws as indicated from the right side covers.
    • Most of the screws in this printer are identical - the ones that are different will be noted as such.
  10. HP Color LaserJet 2600n Fading Color Fix: step 10, image 1 of 3 HP Color LaserJet 2600n Fading Color Fix: step 10, image 2 of 3 HP Color LaserJet 2600n Fading Color Fix: step 10, image 3 of 3
    • Release tabs on the right base cover and right cover.
    • Some of these tabs are inside the printer, so you will need to open the door and look along the right side.
  11. HP Color LaserJet 2600n Fading Color Fix: step 11, image 1 of 3 HP Color LaserJet 2600n Fading Color Fix: step 11, image 2 of 3 HP Color LaserJet 2600n Fading Color Fix: step 11, image 3 of 3
    • Remove the right base cover and right cover from the printer.
  12. HP Color LaserJet 2600n Fading Color Fix: step 12, image 1 of 1
    • Place the device right side up once again.
    • Remove the nine indicated Phillips M3 screws from the back plate.
  13. HP Color LaserJet 2600n Fading Color Fix: step 13, image 1 of 2 HP Color LaserJet 2600n Fading Color Fix: step 13, image 2 of 2
    • With the screws removed, lift the back cover from the bottom and remove from the printer.
  14. HP Color LaserJet 2600n Fading Color Fix: step 14, image 1 of 1
    • During the next two steps, do not unplug any of the connections in the example boxed in orange.
  15. HP Color LaserJet 2600n Fading Color Fix: step 15, image 1 of 2 HP Color LaserJet 2600n Fading Color Fix: step 15, image 2 of 2
    • Carefully and gently handle the wires and cables in the printer. They may break or bend, rendering your printer inoperable.
    • Remove the ribbon cable by pulling directly along the cable.
    • Remove the white connector by pressing down on the tab and pulling out.
    • Pull the purple wire connectors directly out. You do not need to mark which cable goes where, as they are all unique sizes.
  16. HP Color LaserJet 2600n Fading Color Fix: step 16, image 1 of 2 HP Color LaserJet 2600n Fading Color Fix: step 16, image 2 of 2
    • Remove the four ribbon cables gently from the right edge of the circuit board assembly.
    • Remove the final two wires by pulling them straight out.
  17. HP Color LaserJet 2600n Fading Color Fix: step 17, image 1 of 1
    • Unwind the cables from the black harness on the top and right edges of the circuit board assembly.
  18. HP Color LaserJet 2600n Fading Color Fix: step 18, image 1 of 1
    • Depress the indicated tabs and remove the corner wiring harness from the circuit board assembly.
  19. HP Color LaserJet 2600n Fading Color Fix: step 19, image 1 of 2 HP Color LaserJet 2600n Fading Color Fix: step 19, image 2 of 2
    • Slide the top wiring harness to the left and remove it from the circuit board assembly.
  20. HP Color LaserJet 2600n Fading Color Fix: step 20, image 1 of 1
    • Remove the eleven indicated Phillips M3 screws from the circuit board assembly.
  21. HP Color LaserJet 2600n Fading Color Fix: step 21, image 1 of 2 HP Color LaserJet 2600n Fading Color Fix: step 21, image 2 of 2
    • Remove the circuit board assembly from the printer, being cautious of the wires and cables,
  22. HP Color LaserJet 2600n Fading Color Fix: step 22, image 1 of 1
    • Remove the two ribbon cables gently from the optical sub-assembly.
    • These ribbon cables are hard to replace. If you are having trouble, try asking someone with smaller hands! Be gentle, ribbon cables are not the most robust connectors.
  23. HP Color LaserJet 2600n Fading Color Fix: step 23, image 1 of 1
    • Tilt the printer forward and remove the Phillips screw with a lock-washer from the bottom area of the printer.
    • The lock-washer is attached to the screw, so you do not need to worry about losing it.
  24. HP Color LaserJet 2600n Fading Color Fix: step 24, image 1 of 2 HP Color LaserJet 2600n Fading Color Fix: step 24, image 2 of 2
    • Set the printer back down and remove two more Phillips screws with integrated lock-washers, which releases the optical sub-assembly.
    • Remove the optical sub-assembly, this is what you need to repair.
  25. HP Color LaserJet 2600n Fading Color Fix: step 25, image 1 of 2 HP Color LaserJet 2600n Fading Color Fix: step 25, image 2 of 2
    • Place the optical sub-assembly with the side that was facing you down.
    • Remove the indicated black screw.
    • Unhook and save the indicated spring.
    • Remove the top plate from the optical sub-assembly.
  26. HP Color LaserJet 2600n Fading Color Fix: step 26, image 1 of 3 HP Color LaserJet 2600n Fading Color Fix: step 26, image 2 of 3 HP Color LaserJet 2600n Fading Color Fix: step 26, image 3 of 3
    • These are lenses, mirrors, and sensors used by the printer to determine how it is printing. Any damage will affect the quality of printing.
    • Using a clean cotton swab or lens brush, GENTLY clean the visible sides of every clear or reflective surface you can find.
    • Do not scratch or rub the optics, use a brushing motion instead.
    • For more details on what you are doing and why, refer to the document mentioned in the introduction.
  27. HP Color LaserJet 2600n Fading Color Fix: step 27, image 1 of 1
    • Follow up with a light blast of compressed air on all of the surfaces you cleaned.
    • Your printer should now be fully functional! Except for the part where it is disassembled.
    • To reassemble your device, repeat these steps in reverse order.
Jay Miley
5,058 Reputation
13 Guides authored
Cal Poly, Team 10-55, Amido Spring 2014 Member of Cal Poly, Team 10-55, Amido Spring 2014
CPSU-AMIDO-S14S10G55
4 Members
31 Guides authored
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 101
All Time: 30,731
