Roomba 560 Deep Cleaning
  1. Roomba 560 Deep Cleaning, Roomba 560 Deep Cleaning: step 1, image 1 of 1
    • Remove dust bin from Roomba. This will be the first sub-assembly cleaned.
  2. Roomba 560 Deep Cleaning: step 2, image 1 of 2 Roomba 560 Deep Cleaning: step 2, image 2 of 2
    • Open red dust-bin cover. Remove debris from the dust-bin.
    • Remove the filter from the red dust-bin cover.
    • Remove the red dust-bin cover from the bin by gently pressing on the red cover near the hinge.
  3. Roomba 560 Deep Cleaning: step 3, image 1 of 2 Roomba 560 Deep Cleaning: step 3, image 2 of 2
    • Turn over the dust-bin.
    • Remove 6 screws from the clear bottom dust-bin cover.
    • Remove the clear bottom dust-bin cover.
  4. Roomba 560 Deep Cleaning: step 4, image 1 of 3 Roomba 560 Deep Cleaning: step 4, image 2 of 3 Roomba 560 Deep Cleaning: step 4, image 3 of 3
    • Remove three screws from the remaining dust-bin assembly.
    • Lift to remove middle plate from dust-bin assembly.
    • Slide out and remove exhaust grill from dust-bin assembly.
  5. Roomba 560 Deep Cleaning: step 5, image 1 of 2 Roomba 560 Deep Cleaning: step 5, image 2 of 2
    • Turn over top dust-bin plate so the release button is facing up.
    • Remove screw from top plate.
    • Remove blower assembly, push-button, and spring.
  6. Roomba 560 Deep Cleaning: step 6, image 1 of 3 Roomba 560 Deep Cleaning: step 6, image 2 of 3 Roomba 560 Deep Cleaning: step 6, image 3 of 3
    • Remove two screws from blower assembly.
    • Clean dirt and debris from top of blower assembly.
    • Carefully lift top from blower assembly. DO NOT DETACH WIRES.
    • Clean underside of blower cover and around blower.
    • Replace blower cover with two screws.
  7. Roomba 560 Deep Cleaning: step 7, image 1 of 3 Roomba 560 Deep Cleaning: step 7, image 2 of 3 Roomba 560 Deep Cleaning: step 7, image 3 of 3
    • Turn over blower assembly
    • Clean underside surface of blower assembly.
    • Clean fan blades using a cotton swab.
    • Turn blower assembly on its side.
    • Again, clean fan blades using a cotton swab.
  8. Roomba 560 Deep Cleaning: step 8, image 1 of 1
    • Clean all surfaces of the top plate of the dust bin.
  9. Roomba 560 Deep Cleaning: step 9, image 1 of 1
    • Clean all sides of vent grill and between grill slats.
  10. Roomba 560 Deep Cleaning: step 10, image 1 of 1
    • Clean all surface of the middle plate of the dust bin.
    • Clean between the teeth on the front edge of the plate.
  11. Roomba 560 Deep Cleaning: step 11, image 1 of 3 Roomba 560 Deep Cleaning: step 11, image 2 of 3 Roomba 560 Deep Cleaning: step 11, image 3 of 3
    • Re-assemble the blower assembly, vent grill, button, button spring, and top & middle dust-bin plates.
    • Make sure blower assembly slides into the two channels.
    • Replace 3 screws on middle plate and 1 screw on top plate.
  12. Roomba 560 Deep Cleaning: step 12, image 1 of 3 Roomba 560 Deep Cleaning: step 12, image 2 of 3 Roomba 560 Deep Cleaning: step 12, image 3 of 3
    • Clean all surfaces of the clear dust bin cover.
    • Pull off the rubber strip and clean under the rubber strip.
    • Clean all surfaces of the rubber strip.
    • Re-install rubber strip.
  13. Roomba 560 Deep Cleaning: step 13, image 1 of 3 Roomba 560 Deep Cleaning: step 13, image 2 of 3 Roomba 560 Deep Cleaning: step 13, image 3 of 3
    • Clean all surfaces of the red dust-bin cover.
    • Use a small flathead screwdriver or pick to clean inside corners.
    • Replace filter with new filter for best results.
  14. Roomba 560 Deep Cleaning: step 14, image 1 of 3 Roomba 560 Deep Cleaning: step 14, image 2 of 3 Roomba 560 Deep Cleaning: step 14, image 3 of 3
    • Re-attach clear dust-bin cover to dust-bin assembly (see step 11) with six screws.
    • Insert red dust-bin cover.
    • Set clean dust-bin aside.
  15. Roomba 560 Deep Cleaning: step 15, image 1 of 3 Roomba 560 Deep Cleaning: step 15, image 2 of 3 Roomba 560 Deep Cleaning: step 15, image 3 of 3
    • Turn Roomba upside-down so the brushes are facing up.
    • Open brush cage by pressing on yellow tabs and pulling up on the green brush cage lid.
    • Remove both brushes, lifting from the right side of the brushes.
  16. Roomba 560 Deep Cleaning: step 16, image 1 of 3 Roomba 560 Deep Cleaning: step 16, image 2 of 3 Roomba 560 Deep Cleaning: step 16, image 3 of 3
    • Remove the two yellow endcaps from the bristle brush.
    • Run the brush through the red bristle cleaning tool, included with your Roomba.
    • Repeat several times until the the cleaning tool no longer picks up hair/fibers.
  17. Roomba 560 Deep Cleaning: step 17, image 1 of 3 Roomba 560 Deep Cleaning: step 17, image 2 of 3 Roomba 560 Deep Cleaning: step 17, image 3 of 3
    • Clip the zip-tie with a pair of snips and remove the zip-tie from the brush.
    • Remove four screws from the ends of the brush.
    • Pull apart green brush housing.
  18. Roomba 560 Deep Cleaning: step 18, image 1 of 3 Roomba 560 Deep Cleaning: step 18, image 2 of 3 Roomba 560 Deep Cleaning: step 18, image 3 of 3
    • Spray bristles with an all-purpose cleaning solution.
    • Squeeze bristle rod with a paper towel and run bristle rod through paper towel.
    • Repeat several times until bristles are clean.
  19. Roomba 560 Deep Cleaning: step 19, image 1 of 3 Roomba 560 Deep Cleaning: step 19, image 2 of 3 Roomba 560 Deep Cleaning: step 19, image 3 of 3
    • Remove yellow bearing from green bristle housing.
    • Clean yellow bearing and hair/fibers from the axle.
    • Clean all surfaces of both parts of the green bristle brush housing.
  20. Roomba 560 Deep Cleaning: step 20, image 1 of 3 Roomba 560 Deep Cleaning: step 20, image 2 of 3 Roomba 560 Deep Cleaning: step 20, image 3 of 3
    • To re-assemble the green brush housing, push the green housing against the side of one row of bristles.
    • Push on the bristles until they no longer fan out and the bristle tips are lined up with the long slot in the green brush housing.
    • Rotate the green brush housing so the line of bristles goes through the slot in the green brush housing.
    • Repeat step for the other green brush housing.
  21. Roomba 560 Deep Cleaning: step 21, image 1 of 2 Roomba 560 Deep Cleaning: step 21, image 2 of 2
    • Replace 4 screws on the ends of the brush.
    • Run the zip-tie through holes near the center of the brush. Secure the zip tie and clip of any excess.
    • Re-attach yellow bearing and two yellow endcaps.
    • Set aside for later installation.
  22. Roomba 560 Deep Cleaning: step 22, image 1 of 3 Roomba 560 Deep Cleaning: step 22, image 2 of 3 Roomba 560 Deep Cleaning: step 22, image 3 of 3
    • Remove plastic sweeper bar from brush housing.
    • Remove yellow plastic end-piece from axle.
    • Remove hair and debris from both ends of axle. You may need to use a small pick or manicuring scissors to remove hair from the axle.
  23. Roomba 560 Deep Cleaning: step 23, image 1 of 2 Roomba 560 Deep Cleaning: step 23, image 2 of 2
    • Spray all surfaces with cleaning solution. Wipe clean with paper towel. Follow up with smaller cleaning tools if necessary.
    • Clean yellow plastic end piece with cleaning solution and paper towel or cotton swab.
    • Replace yellow plastic end piece on axle.
  24. Roomba 560 Deep Cleaning: step 24, image 1 of 3 Roomba 560 Deep Cleaning: step 24, image 2 of 3 Roomba 560 Deep Cleaning: step 24, image 3 of 3
    • With Roomba wheels-up, grab onto front wheel and firmly pull straight up to remove wheel.
    • From the underside of the wheel housing, push the wheel out of the housing.
  25. Roomba 560 Deep Cleaning: step 25, image 1 of 3 Roomba 560 Deep Cleaning: step 25, image 2 of 3 Roomba 560 Deep Cleaning: step 25, image 3 of 3
    • Remove the axle from the wheel.
    • Thoroughly clean the axle and the wheel with a paper towel and cleaning solution.
    • Thoroughly clean wheel housing with paper towel, cotton swab, and cleaning solution.
    • Re-assemble wheel housing by inserting axle in wheel and pressing wheel with axle back into wheel housing.
    • DO NOT insert wheel housing back into Roomba body. That will be done later.
  26. Roomba 560 Deep Cleaning: step 26, image 1 of 2 Roomba 560 Deep Cleaning: step 26, image 2 of 2
    • Remove center screw from edge brush and set aside.
    • Remove brush from Roomba body by lifting on any set of bristles.
  27. Roomba 560 Deep Cleaning: step 27, image 1 of 3 Roomba 560 Deep Cleaning: step 27, image 2 of 3 Roomba 560 Deep Cleaning: step 27, image 3 of 3
    • Place edge brush on paper towel and douse with cleaning solution.
    • Rub each set of bristles with paper towel until bristles appear clean and free of debris.
    • Place edge brush on a clean paper towel and douse with bleach water.
    • Rub each set of bristles with paper towel as you did earlier with the cleaning solution.
    • Set aside for later assembly.
  28. Roomba 560 Deep Cleaning: step 28, image 1 of 3 Roomba 560 Deep Cleaning: step 28, image 2 of 3 Roomba 560 Deep Cleaning: step 28, image 3 of 3
    • Unscrew 4 screws from the underside of the Roomba. Screws will separate from underside plastic plate.
    • Spray with cleaning solution and clean with paper towel. Follow up with smaller cleaning tools if needed.
  29. Roomba 560 Deep Cleaning: step 29, image 1 of 3 Roomba 560 Deep Cleaning: step 29, image 2 of 3 Roomba 560 Deep Cleaning: step 29, image 3 of 3
    • Unscrew 4 screws around the brush cage housing. Screws will not separate from brush cage housing.
    • Lift brush cage assembly from Roomba body.
  30. Roomba 560 Deep Cleaning: step 30, image 1 of 3 Roomba 560 Deep Cleaning: step 30, image 2 of 3 Roomba 560 Deep Cleaning: step 30, image 3 of 3
    • Place the brush assembly with the blue housing facing down.
    • Open the cage lid
    • Remove the brush cage lid by firmly pulling up at the hinges. Remove one hinge at a time.
    • Clean all surfaces of the brush cage with cleaning solution, paper towels, and cotton swabs. You may need to use a pick to clean tight corners and slots.
  31. Roomba 560 Deep Cleaning: step 31, image 1 of 3 Roomba 560 Deep Cleaning: step 31, image 2 of 3 Roomba 560 Deep Cleaning: step 31, image 3 of 3
    • Place brush cage housing upside down (blue part up).
    • Remove screw securing daughtercard.
    • Move black and red wires inside the blue housing. This is required when separating the green brush cage assembly from the blue housing.
  32. Roomba 560 Deep Cleaning: step 32, image 1 of 2 Roomba 560 Deep Cleaning: step 32, image 2 of 2
    • Remove red sticker. This is holding down a small, round, weight attached to a cable.
    • Pull the cable through the channel. This cable limits travel of the blue housing.
  33. Roomba 560 Deep Cleaning: step 33, image 1 of 3 Roomba 560 Deep Cleaning: step 33, image 2 of 3 Roomba 560 Deep Cleaning: step 33, image 3 of 3
    • Flip the brush cage assembly over. Arrange so the two "arms" are facing you.
    • On one side, pull apart the green cage arm from the blue housing arm and lift out.
    • Repeat on the other arm. The green brush cage assembly will lift out of the blue housing.
  34. Roomba 560 Deep Cleaning: step 34, image 1 of 3 Roomba 560 Deep Cleaning: step 34, image 2 of 3 Roomba 560 Deep Cleaning: step 34, image 3 of 3
    • Clean all surfaces of the blue housing with cleaning solution, paper towels, and cotton swabs. Use a pick to clean the debris out of tight spaces.
  35. Roomba 560 Deep Cleaning: step 35, image 1 of 3 Roomba 560 Deep Cleaning: step 35, image 2 of 3 Roomba 560 Deep Cleaning: step 35, image 3 of 3
    • Place green brush cage upside down.
    • Remove 2 screws securing the square sensor cover. Set sensor cover aside.
    • Remove daughtercard from daughtercard mount.
  36. Roomba 560 Deep Cleaning: step 36, image 1 of 2 Roomba 560 Deep Cleaning: step 36, image 2 of 2
    • Flip the green brush cage over.
    • Remove the sensor by gently pressing on the silver disc.
  37. Roomba 560 Deep Cleaning: step 37, image 1 of 3 Roomba 560 Deep Cleaning: step 37, image 2 of 3 Roomba 560 Deep Cleaning: step 37, image 3 of 3
    • Turn green brush cage over so the motor is facing up.
    • Remove 2 screws securing the grey motor support to the green brush cage.
    • Pull the motor sideways out of the gearbox.
    • Remove the foam bushing and set aside.
  38. Roomba 560 Deep Cleaning: step 38, image 1 of 3 Roomba 560 Deep Cleaning: step 38, image 2 of 3 Roomba 560 Deep Cleaning: step 38, image 3 of 3
    • Remove 6 screws from the gear housing.
    • Pull front cover away from the brush cage body.
  39. Roomba 560 Deep Cleaning: step 39, image 1 of 1
    • Clean all surfaces of the green housing with cleaning solution, paper towels, and cotton swabs. Use a pick to clean the debris out of tight spaces.
HoyeBoye
1,312 Reputation
2 Guides authored
Past 24 Hours: 4
Past 7 Days: 31
Past 30 Days: 157
All Time: 63,533
