Introduction
This guide will walk you through a complete disassembly of the Roomba's dust-bin, brush assemblies, and outer-housing.
Remove dust bin from Roomba. This will be the first sub-assembly cleaned.
Open red dust-bin cover. Remove debris from the dust-bin.
Remove the filter from the red dust-bin cover.
Remove the red dust-bin cover from the bin by gently pressing on the red cover near the hinge.
Turn over the dust-bin.
Remove 6 screws from the clear bottom dust-bin cover.
Remove the clear bottom dust-bin cover.
Remove three screws from the remaining dust-bin assembly.
Lift to remove middle plate from dust-bin assembly.
Slide out and remove exhaust grill from dust-bin assembly.
Turn over top dust-bin plate so the release button is facing up.
Remove screw from top plate.
Remove blower assembly, push-button, and spring.
Remove two screws from blower assembly.
Clean dirt and debris from top of blower assembly.
Carefully lift top from blower assembly. DO NOT DETACH WIRES.
Clean underside of blower cover and around blower.
Replace blower cover with two screws.
Turn over blower assembly
Clean underside surface of blower assembly.
Clean fan blades using a cotton swab.
Turn blower assembly on its side.
Again, clean fan blades using a cotton swab.
Clean all surface of the middle plate of the dust bin.
Clean between the teeth on the front edge of the plate.
Re-assemble the blower assembly, vent grill, button, button spring, and top & middle dust-bin plates.
Make sure blower assembly slides into the two channels.
Replace 3 screws on middle plate and 1 screw on top plate.
Clean all surfaces of the clear dust bin cover.
Pull off the rubber strip and clean under the rubber strip.
Clean all surfaces of the rubber strip.
Re-install rubber strip.
Clean all surfaces of the red dust-bin cover.
Use a small flathead screwdriver or pick to clean inside corners.
Replace filter with new filter for best results.
Re-attach clear dust-bin cover to dust-bin assembly (see step 11) with six screws.
Insert red dust-bin cover.
Set clean dust-bin aside.
Turn Roomba upside-down so the brushes are facing up.
Open brush cage by pressing on yellow tabs and pulling up on the green brush cage lid.
Remove both brushes, lifting from the right side of the brushes.
Remove the two yellow endcaps from the bristle brush.
Run the brush through the red bristle cleaning tool, included with your Roomba.
Repeat several times until the the cleaning tool no longer picks up hair/fibers.
Clip the zip-tie with a pair of snips and remove the zip-tie from the brush.
Remove four screws from the ends of the brush.
Pull apart green brush housing.
Spray bristles with an all-purpose cleaning solution.
Squeeze bristle rod with a paper towel and run bristle rod through paper towel.
Repeat several times until bristles are clean.
Remove yellow bearing from green bristle housing.
Clean yellow bearing and hair/fibers from the axle.
Clean all surfaces of both parts of the green bristle brush housing.
To re-assemble the green brush housing, push the green housing against the side of one row of bristles.
Push on the bristles until they no longer fan out and the bristle tips are lined up with the long slot in the green brush housing.
Rotate the green brush housing so the line of bristles goes through the slot in the green brush housing.
Repeat step for the other green brush housing.
Replace 4 screws on the ends of the brush.
Run the zip-tie through holes near the center of the brush. Secure the zip tie and clip of any excess.
Re-attach yellow bearing and two yellow endcaps.
Set aside for later installation.
Remove plastic sweeper bar from brush housing.
Remove yellow plastic end-piece from axle.
Remove hair and debris from both ends of axle. You may need to use a small pick or manicuring scissors to remove hair from the axle.
Spray all surfaces with cleaning solution. Wipe clean with paper towel. Follow up with smaller cleaning tools if necessary.
Clean yellow plastic end piece with cleaning solution and paper towel or cotton swab.
Replace yellow plastic end piece on axle.
With Roomba wheels-up, grab onto front wheel and firmly pull straight up to remove wheel.
From the underside of the wheel housing, push the wheel out of the housing.
Remove the axle from the wheel.
Thoroughly clean the axle and the wheel with a paper towel and cleaning solution.
Thoroughly clean wheel housing with paper towel, cotton swab, and cleaning solution.
Re-assemble wheel housing by inserting axle in wheel and pressing wheel with axle back into wheel housing.
DO NOT insert wheel housing back into Roomba body. That will be done later.
Remove center screw from edge brush and set aside.
Remove brush from Roomba body by lifting on any set of bristles.
Place edge brush on paper towel and douse with cleaning solution.
Rub each set of bristles with paper towel until bristles appear clean and free of debris.
Place edge brush on a clean paper towel and douse with bleach water.
Rub each set of bristles with paper towel as you did earlier with the cleaning solution.
Set aside for later assembly.
Unscrew 4 screws from the underside of the Roomba. Screws will separate from underside plastic plate.
Spray with cleaning solution and clean with paper towel. Follow up with smaller cleaning tools if needed.
Unscrew 4 screws around the brush cage housing. Screws will not separate from brush cage housing.
Lift brush cage assembly from Roomba body.
Place the brush assembly with the blue housing facing down.
Open the cage lid
Remove the brush cage lid by firmly pulling up at the hinges. Remove one hinge at a time.
Clean all surfaces of the brush cage with cleaning solution, paper towels, and cotton swabs. You may need to use a pick to clean tight corners and slots.
Place brush cage housing upside down (blue part up).
Remove screw securing daughtercard.
Move black and red wires inside the blue housing. This is required when separating the green brush cage assembly from the blue housing.
Remove red sticker. This is holding down a small, round, weight attached to a cable.
Pull the cable through the channel. This cable limits travel of the blue housing.
Flip the brush cage assembly over. Arrange so the two "arms" are facing you.
On one side, pull apart the green cage arm from the blue housing arm and lift out.
Repeat on the other arm. The green brush cage assembly will lift out of the blue housing.
Clean all surfaces of the blue housing with cleaning solution, paper towels, and cotton swabs. Use a pick to clean the debris out of tight spaces.
Place green brush cage upside down.
Remove 2 screws securing the square sensor cover. Set sensor cover aside.
Remove daughtercard from daughtercard mount.
Turn green brush cage over so the motor is facing up.
Remove 2 screws securing the grey motor support to the green brush cage.
Pull the motor sideways out of the gearbox.
Remove the foam bushing and set aside.
Clean all surfaces of the green housing with cleaning solution, paper towels, and cotton swabs. Use a pick to clean the debris out of tight spaces.
