How to create a virtual machine on VMware Workstation Pro 17
  1. How to create a virtual machine on VMware Workstation Pro 17, Accessing the New VM wizard: step 1, image 1 of 1
    • Open VMware Workstation Pro 17.
    • Go to File > New Virtual Machine..
    Ask FixBot
  2. How to create a virtual machine on VMware Workstation Pro 17, First Screen: step 2, image 1 of 1
    • Since we're doing the Custom setup, choose the second radio button and press "Next".
    Ask FixBot
  3. How to create a virtual machine on VMware Workstation Pro 17, Second Screen: step 3, image 1 of 1
    • Here you can choose what VMware version you want the VM to be for. You can set an older one, and it will still run on Pro 17, but potentially with less features. If you're unsure, leave it at the default.
    Ask FixBot
  4. How to create a virtual machine on VMware Workstation Pro 17, Third Screen (OS Installation): step 4, image 1 of 1
    • Next, choose where you want to install the OS from. You can either use a disc in a physical drive, an ISO image, or none for now.
    • If you're using a modern version of Windows, VMware will use Easy Install (Unattended mode) during Setup. The next step will go over these options. If you're not using one of these versions, you can skip the next step.
    Ask FixBot
  5. How to create a virtual machine on VMware Workstation Pro 17, Easy Install Screen: step 5, image 1 of 1
    • First, if you have one, enter the Product Key for Windows.
    • Next, choose the skew you want to install. You should pick the one your product key is for
    • Lastly, enter the name for the user (default is your username) and your password.
    • If you enter a password, you can also have Windows log in to that account automatically by checking the box at the bottom.
    Ask FixBot
  6. How to create a virtual machine on VMware Workstation Pro 17, VM Name and Location: step 6, image 1 of 1
    • Choose a name for the VM and where it will be stored.
    • You can change the path VMware saves to by default in Edit > Preferences.
    Ask FixBot
  7. How to create a virtual machine on VMware Workstation Pro 17, Firmware Type: step 7, image 1 of 1
    • Here you can choose between BIOS and UEFI. For older operating systems, choose BIOS. For newer operating systems, choose UEFI and, especially for newer versions of Windows, you may want to enable Secure Boot.
    Ask FixBot
  8. How to create a virtual machine on VMware Workstation Pro 17, Processor Configuration: step 8, image 1 of 1
    • Here you can set the number of processors and how many cores each processor has. What's best will depend on the host machine and guest OS, but 2 processors and 2 cores can be a good default, or you can stick with the 1 processor and 1 core default. You can change it at any time.
    Ask FixBot
  9. How to create a virtual machine on VMware Workstation Pro 17, VM Memory Configuration: step 9, image 1 of 1
    • Here you can specify how much RAM is allocated to the VM. The allocated amount must be less than the amount your host has.
    • Some operating systems may limit the amount of RAM you can specify. Win9x systems have a max of 1GB.
    Ask FixBot
  10. How to create a virtual machine on VMware Workstation Pro 17, Network Type: step 10, image 1 of 1
    • Here you can specify the type of networking the VM will have.
    • A good default is NAT, but you'll want to use Bridged if you need the VM to have its own IP on your network, which can be good for stuff like servers.
    Ask FixBot
  11. How to create a virtual machine on VMware Workstation Pro 17, I/O Controller Types: step 11, image 1 of 1
    • Here you can choose the type of I/O Controller the VM will use. Keep it at the default if you're not sure.
    Ask FixBot
  12. How to create a virtual machine on VMware Workstation Pro 17, Disk Type: step 12, image 1 of 1
    • Next, choose the type of disk the virtual hard disk will be. You may need to change this to get some Operating Systems to recognize the virtual hard disk.
    Ask FixBot
  13. How to create a virtual machine on VMware Workstation Pro 17, Select a Disk: step 13, image 1 of 1
    • Next, choose what kind of hard disk you want to use. You can either create a new one, use an existing one, or if you have another drive connected to your computer, use that physical drive.
    • You will need administrator privileges to use a physical drive as the VM's hard disk.
    Ask FixBot
  14. How to create a virtual machine on VMware Workstation Pro 17, Disk Capacity: step 14, image 1 of 2 How to create a virtual machine on VMware Workstation Pro 17, Disk Capacity: step 14, image 2 of 2
    • If you're creating a virtual hard disk, you can specify how big you want the disk to be, whether to use one file or multiple files for the disk, and if you want to allocate all of the space now.
    • It's more performance efficient to use one file for the hard disk.
    • On the next screen, you can specify the virtual disk's name (default is the VM's name)
    Ask FixBot
  15. How to create a virtual machine on VMware Workstation Pro 17, Settings Overview: step 15, image 1 of 1
    • Here you can review your settings that you specified in the previous steps. You can also click "Customize Hardware..." to add to or modify the VM's hardware.
    • You can also tell VMware to boot the VM after creation.
    Ask FixBot
Finish Line
Sean-e
676 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 72
All Time: 789
