How to clean and maintain your Vape Mod
  1. How to clean and maintain your Vape Mod, How to clean and maintain your Vape Mod: step 1, image 1 of 3 How to clean and maintain your Vape Mod, How to clean and maintain your Vape Mod: step 1, image 2 of 3 How to clean and maintain your Vape Mod, How to clean and maintain your Vape Mod: step 1, image 3 of 3
    • Although maintenance for your Vape Mod shouldn't be dangerous, it can be messy. It is recommended to do this on top of a paper towel.
    • Start by removing the top cap of your Vape Mod.
  2. How to clean and maintain your Vape Mod: step 2, image 1 of 3 How to clean and maintain your Vape Mod: step 2, image 2 of 3 How to clean and maintain your Vape Mod: step 2, image 3 of 3
    • Unscrew RDA (rebuildable dripping atomizer) and take it off.
  3. How to clean and maintain your Vape Mod: step 3, image 1 of 3 How to clean and maintain your Vape Mod: step 3, image 2 of 3 How to clean and maintain your Vape Mod: step 3, image 3 of 3
    • Many Vape Mods are different, you might have to take out your battery in a different way than shown.
    • At the bottom of the tube, unscrew the firing pin.
    • Take the battery out of the Vape Mod.
  4. How to clean and maintain your Vape Mod: step 4, image 1 of 3 How to clean and maintain your Vape Mod: step 4, image 2 of 3 How to clean and maintain your Vape Mod: step 4, image 3 of 3
    • Inspect all of the parts that will need to be cleaned:
    • The firing pin
    • The RDA threading
    • The bottom of the inside of the tube
  5. How to clean and maintain your Vape Mod: step 5, image 1 of 2 How to clean and maintain your Vape Mod: step 5, image 2 of 2
    • Clean the Firing pin by dipping a paper towel into hot water.
    • Carefully rotate the hot towel around the middle area, rubbing the grime away.
  6. How to clean and maintain your Vape Mod: step 6, image 1 of 3 How to clean and maintain your Vape Mod: step 6, image 2 of 3 How to clean and maintain your Vape Mod: step 6, image 3 of 3
    • Get a new paper towel wet with the hot water.
    • Clean the RDA threading by rotating the wet paper towel back and forth across it.
  7. How to clean and maintain your Vape Mod: step 7, image 1 of 3 How to clean and maintain your Vape Mod: step 7, image 2 of 3 How to clean and maintain your Vape Mod: step 7, image 3 of 3
    • Twist it until it can easily fit inside of the tube.
    • Use your finger or another long tool to rotate the paper towel along the sides and the bottom of the tube.
  8. How to clean and maintain your Vape Mod: step 8, image 1 of 3 How to clean and maintain your Vape Mod: step 8, image 2 of 3 How to clean and maintain your Vape Mod: step 8, image 3 of 3
    • Put your Vape Mod back together by doing steps 1 - 2 in reverse. (Leave the mouthpiece of the top cap off).
    • Careful, firing your Vape Mod produces heat and can make the device HOT!
    • Fire your Vape Mod. If the coils are heating up, it has been fixed!
If your Vape Mod is still not firing, consider getting a new build.
13 other people completed this guide.
Jessie Smith
677 Reputation
1 Guide authored
Cal Poly, Team 14-3, Green Fall 2015 Member of Cal Poly, Team 14-3, Green Fall 2015
CPSU-GREEN-F15S14G3
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 30
All Time: 10,621
