How to clean and maintain your Vape Mod
  1. How to clean and maintain your Vape Mod, How to clean and maintain your Vape Mod: step 1, image 1 of 3 How to clean and maintain your Vape Mod, How to clean and maintain your Vape Mod: step 1, image 2 of 3 How to clean and maintain your Vape Mod, How to clean and maintain your Vape Mod: step 1, image 3 of 3
    • Although maintenance for your Vape Mod shouldn't be dangerous, it can be messy. It is recommended to do this on top of a paper towel.
    • Start by removing the top cap of your Vape Mod.
    Ask FixBot
  2. How to clean and maintain your Vape Mod: step 2, image 1 of 3 How to clean and maintain your Vape Mod: step 2, image 2 of 3 How to clean and maintain your Vape Mod: step 2, image 3 of 3
    • Unscrew RDA (rebuildable dripping atomizer) and take it off.
    Ask FixBot
  3. How to clean and maintain your Vape Mod: step 3, image 1 of 3 How to clean and maintain your Vape Mod: step 3, image 2 of 3 How to clean and maintain your Vape Mod: step 3, image 3 of 3
    • Many Vape Mods are different, you might have to take out your battery in a different way than shown.
    • At the bottom of the tube, unscrew the firing pin.
    • Take the battery out of the Vape Mod.
    Ask FixBot
  4. How to clean and maintain your Vape Mod: step 4, image 1 of 3 How to clean and maintain your Vape Mod: step 4, image 2 of 3 How to clean and maintain your Vape Mod: step 4, image 3 of 3
    • Inspect all of the parts that will need to be cleaned:
    • The firing pin
    • The RDA threading
    • The bottom of the inside of the tube
    Ask FixBot
  5. How to clean and maintain your Vape Mod: step 5, image 1 of 2 How to clean and maintain your Vape Mod: step 5, image 2 of 2
    • Clean the Firing pin by dipping a paper towel into hot water.
    • Carefully rotate the hot towel around the middle area, rubbing the grime away.
    Ask FixBot
  6. How to clean and maintain your Vape Mod: step 6, image 1 of 3 How to clean and maintain your Vape Mod: step 6, image 2 of 3 How to clean and maintain your Vape Mod: step 6, image 3 of 3
    • Get a new paper towel wet with the hot water.
    • Clean the RDA threading by rotating the wet paper towel back and forth across it.
    Ask FixBot
  7. How to clean and maintain your Vape Mod: step 7, image 1 of 3 How to clean and maintain your Vape Mod: step 7, image 2 of 3 How to clean and maintain your Vape Mod: step 7, image 3 of 3
    • Twist it until it can easily fit inside of the tube.
    • Use your finger or another long tool to rotate the paper towel along the sides and the bottom of the tube.
    Ask FixBot
  8. How to clean and maintain your Vape Mod: step 8, image 1 of 3 How to clean and maintain your Vape Mod: step 8, image 2 of 3 How to clean and maintain your Vape Mod: step 8, image 3 of 3
    • Put your Vape Mod back together by doing steps 1 - 2 in reverse. (Leave the mouthpiece of the top cap off).
    • Careful, firing your Vape Mod produces heat and can make the device HOT!
    • Fire your Vape Mod. If the coils are heating up, it has been fixed!
    Ask FixBot
If your Vape Mod is still not firing, consider getting a new build.
14 other people completed this guide.
Jessie Smith
704 Reputation
1 Guide authored
Cal Poly, Team 14-3, Green Fall 2015 Member of Cal Poly, Team 14-3, Green Fall 2015
CPSU-GREEN-F15S14G3
4 Members
17 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 86
All Time: 11,865
