Carburetor Tank Maintenance
  1. Carburetor Tank Maintenance, Carburetor Tank Maintenance: step 1, image 1 of 1
    • Make sure the the engine is off and the spark plug wire is removed and away from the spark plug before beginning.
    • Use a Flathead #4 screw driver to remove the 40mm screw that holds the air filter case in place.
  2. Carburetor Tank Maintenance: step 2, image 1 of 1
    • Use your hands to pull the air filter case out of the hinge at the bottom.
  3. Carburetor Tank Maintenance: step 3, image 1 of 2 Carburetor Tank Maintenance: step 3, image 2 of 2
    • Use a socket wrench with a 5/16" hex bit to remove three 20mm bolts behind the air filter.
    • Use your hand to remove the plastic backing to the air filter, exposing the carburetor.
  4. Carburetor Tank Maintenance: step 4, image 1 of 1
    • Note: There is a plastic washer that may come off when you take off the plastic backing. This is normal; just set it aside and save it for reassembly.
  5. Carburetor Tank Maintenance: step 5, image 1 of 1
    • Use a socket wrench with a ½" hex bit to remove 11mm screw on the bottom of the tank.
  6. Carburetor Tank Maintenance: step 6, image 1 of 2 Carburetor Tank Maintenance: step 6, image 2 of 2
    • Once the bolt is removed from the bottom of the carburetor tank, gently pry open the tank with a metal prying spudger until it pops off. If you do not have a spudger, a flathead screwdriver will work.
    • Completely remove the tank so you can clean it or replace it.
  7. Carburetor Tank Maintenance: step 7, image 1 of 1
    • Inspect the O-ring inside the carburetor tank. If it is dry and worn out, you may need to replace the O-ring before you reassemble your device.
Tim Wirtz
1,058 Reputation
1 Guide authored
Cal Poly, Team 6-31, Amido Winter 2015 Member of Cal Poly, Team 6-31, Amido Winter 2015
CPSU-AMIDO-W15S6G31
4 Members
15 Guides authored
Past 24 Hours: 59
Past 7 Days: 479
Past 30 Days: 2,137
All Time: 131,911
