Cleaning the Ribbon Cables
  1. Cleaning the Ribbon Cables, Outer Shell Disassembly: step 1, image 1 of 2 Cleaning the Ribbon Cables, Outer Shell Disassembly: step 1, image 2 of 2
    • Unplug the device from any energy sources.
    • Lift the top cover of the scanner.
    • Use a plastic opening tool to remove the plastic frame surrounding the glass.
  2. Cleaning the Ribbon Cables: step 2, image 1 of 1
    • Carefully pull the frame away from the glass.
    • If it doesn't remove easily, use the iFixit Opening Tool again to pry stuck sections.
  3. Cleaning the Ribbon Cables: step 3, image 1 of 1
    • Use a T10 screwdriver to unscrew the two screws that fasten the frame to the printer hood.
  4. Cleaning the Ribbon Cables: step 4, image 1 of 2 Cleaning the Ribbon Cables: step 4, image 2 of 2
    • Put your finger behind the panel with the power button.
    • Then, pull the piece outwards.
  5. Cleaning the Ribbon Cables: step 5, image 1 of 2 Cleaning the Ribbon Cables: step 5, image 2 of 2
    • Unscrew the screw inside the power button panel space.
    • Then, unscrew the screw that is across the printer slider.
  6. Cleaning the Ribbon Cables: step 6, image 1 of 1
    • Pull the white circuit board outwards which is located under the small screen.
    • Unplug the small ribbon cable from the circuit board.
    • Be careful when you unplug the ribbon cable not to use too much force. Using too much force may damage or rip the cable.
    • Unplug the small ribbon cable from the circuit board. Be careful when you unplug the ribbon cable not to use too much force. Using too much force may damage or rip the cable.
  7. Cleaning the Ribbon Cables: step 8, image 1 of 2 Cleaning the Ribbon Cables: step 8, image 2 of 2
    • Pull the memory card reader's circuit board out.
    • Detach the white wiring connector from the back of the circuit board.
    • You may need to use a finger nail or a plastic opening tool to detach the white wiring connector from the circuit board.
  8. Cleaning the Ribbon Cables: step 9, image 1 of 2 Cleaning the Ribbon Cables: step 9, image 2 of 2
    • Put your finger behind the small screen.
    • Then, pull it up.
    • Do not hesitate to use force to remove the TouchSmart panel.
    • Disconnect the ribbon cable from the small screen.
  9. Cleaning the Ribbon Cables: step 10, image 1 of 1
    • Pull the printer hood upward.
  10. Cleaning the Ribbon Cables, Cleaning the Ribbon Cables: step 11, image 1 of 1
    • Ribbon Cables connect electronics to one another and flat in appearance and flexible.
    • There are many ribbon cables throughout the printer. After opening up the casing of the printer the ones that are easily accessible are the ones that need cleaning. They all take the same basic process to clean.
  11. Cleaning the Ribbon Cables: step 12, image 1 of 1
    • In order to remove a ribbon cable pull the cable out of its port with a moderate amount of force. Remember the orientation of the cable if you can.
  12. Cleaning the Ribbon Cables: step 13, image 1 of 1
    • After the cable is removed use compressed air to clear dust out of the port, and a dry soft cloth to clean the end of the cable.
Tanner Cook
149 Reputation
1 Guide authored
Cal Poly, Team 2-11, Propen Fall 2012 Member of Cal Poly, Team 2-11, Propen Fall 2012
CPSU-PROPEN-F12S2G11
4 Members
6 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 8,301
