Cleaning The Function Keys
  1. Cleaning The Function Keys, Front and Back Covers: step 1, image 1 of 3 Cleaning The Function Keys, Front and Back Covers: step 1, image 2 of 3 Cleaning The Function Keys, Front and Back Covers: step 1, image 3 of 3
    • Unscrew a total of 6 4.45 mm phillips head screws using a #00 phillips head screwdriver.
    • There are 2 screws on the left side (when looking at the front of the camera).
    • There are 3 screws on the bottom
    • There is 1 screw on the right side
  2. Cleaning The Function Keys: step 2, image 1 of 1
    • Turn to the bottom of the camera.
    • Open the memory card cover by sliding the "CARD/BATT." button up, and then pulling the cover to the left.
  3. Cleaning The Function Keys: step 3, image 1 of 1
    • This is what the SD card/battery compartment looks like when opened.
    • Remove one 4.45mm phillips head screw from the SD card/battery compartment using a #00 phillips head screwdriver.
  4. Cleaning The Function Keys: step 4, image 1 of 2 Cleaning The Function Keys: step 4, image 2 of 2
    • Gently remove the front cover away from the camera body.
    • Tip: Start by loosening the teeth on the left side of the camera next to the battery compartment.
  5. Cleaning The Function Keys: step 5, image 1 of 1
    • The camera should look like this once the front cover is removed.
  6. Cleaning The Function Keys: step 6, image 1 of 3 Cleaning The Function Keys: step 6, image 2 of 3 Cleaning The Function Keys: step 6, image 3 of 3
    • Start from the battery compartment and remove the back cover.
    • Caution: Do not tug on the back cover after it is removed. This could tear the ribbon attaching the back cover to the camera body.
    • Remove the connecting ribbon from the body of the camera using a pair of tweezers.
  7. Cleaning The Function Keys: step 7, image 1 of 1
    • Once the ribbon connecting the back cover is removed, the back of the camera body should look like this.
  8. Cleaning The Function Keys, Cleaning The Function Keys: step 8, image 1 of 1
    • Turn to the back of the camera body. Rub the function keys and surrounding area with a clean cloth dipped in isopropyl alcohol.
Shaelyn Thomas
332 Reputation
4 Guides authored
Cal Poly, Team 8-6, Regan Spring 2011 Member of Cal Poly, Team 8-6, Regan Spring 2011
CPSU-REGAN-S11S8G6
4 Members
22 Guides authored
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 12
All Time: 1,936
