How to change Tool for DeepAccess
    1. How to change Tool for DeepAccess, How to change Tool for DeepAccess: step 1, image 1 of 1
      • Prepare Tools and replacement parts.
      Ask FixBot
    2. How to change Tool for DeepAccess, Remove wedge from transducer: step 2, image 1 of 3 How to change Tool for DeepAccess, Remove wedge from transducer: step 2, image 2 of 3 How to change Tool for DeepAccess, Remove wedge from transducer: step 2, image 3 of 3
      Tool used on this step:
      Buy
      • Grab wegdge with tweezers
      • Loosen the screw. (while holding the wedge)
      • Get rid of the copper screw. To NOT use it more than once
      Ask FixBot
    3. How to change Tool for DeepAccess, Place the new wedge in the transducer.: step 3, image 1 of 3 How to change Tool for DeepAccess, Place the new wedge in the transducer.: step 3, image 2 of 3 How to change Tool for DeepAccess, Place the new wedge in the transducer.: step 3, image 3 of 3
      • Put the wedge in the tranducer from below.
      • Take care, that the Tool Top is flush with the Transducer surface
      • Correct Placement. Tool is flush with transducer.
      • Incorrect Placement. tool is too high.
      Ask FixBot
    4. How to change Tool for DeepAccess, Fasten the copper screw: step 4, image 1 of 2 How to change Tool for DeepAccess, Fasten the copper screw: step 4, image 2 of 2
      • Fasten the screw lightly
      • Tighten the screw just so the wedge does not slip out of the tranducer.
      • in case of appliying too much torque. Use a new screw and get rid of the old one.
      Ask FixBot
    5. How to change Tool for DeepAccess, Adjust wedge heigth with setting gauge: step 5, image 1 of 3 How to change Tool for DeepAccess, Adjust wedge heigth with setting gauge: step 5, image 2 of 3 How to change Tool for DeepAccess, Adjust wedge heigth with setting gauge: step 5, image 3 of 3
      • Place gauge below Tool
      • Loosen the screw so the wedge slides onto the gauge Lever.
      • Lift the gauge up until in contact with the transducer horn.
      • Now the Tool-Top should be flush with the Transducer-Horn
      • Tighten the screw with the torque- wrench
      • Use Torque wrench with 18cN limitation
      Ask FixBot
      • Use tweezers to push the wire down the wire hole, until it Ends some cm below the tool wedge.
      • Use scissors to cut the (contaminated) Wire down to a length of about 1cm below wedge end.
      Ask FixBot
    6. How to change Tool for DeepAccess, Thread Wire through Wedge-hole: step 7, image 1 of 3 How to change Tool for DeepAccess, Thread Wire through Wedge-hole: step 7, image 2 of 3 How to change Tool for DeepAccess, Thread Wire through Wedge-hole: step 7, image 3 of 3
      • Use tweezers to thread the wire through the hole at the end of the wedge.
      • Afet threading pull the wire some cm through the hole.
      Ask FixBot
Hans Panz
311 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 15
All Time: 308
