Shop the Holiday Gift Guide
How to calibrate gimbal on DJI Mavic Mini
Views: 5.8K
View statistics:
Past 24 Hours:
4
Past 7 Days:
40
Past 30 Days:
190
All Time:
5,821
Comments: 9
9 guide comments.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 - 30 minutes
Difficulty: Easy
Community-Contributed Guide
Needs Transcription
This guide is in video form only. Help make it more accessible by transcribing each action of the procedure into a separate step and adding photos.
Introduction
In this video tutorial, I will show you how to calibrate a gimbal camera on a DJI Mavic Mini. This process is necessary after replacing the camera stabilizer, gimbal assembly, or changing the drone motherboard.
Download Programs for Calibration Gimbal :
First script to run calibration
  • py comm_og_service_tool.py --port com pcode GimbalCalib JointCoarse
Second gimbal calibration script
  • py comm_og_service_tool.py --port com pcode GimbalCalib LinearHall
Video Instructions
To reassemble your device, follow these instructions.
Author
with
Arty
34,654 Reputation
110 Guides authored
9 Guide Comments
Does this work for the dji mini se? As I do not see a pcode in the list.
Joshua Dockery - Reply Share
Thank you for your video, for me it gets stuck in the "Info: The Gimbal will slowly move through all positions in all axes," and not responding.. any ideas? Thank you.
Βασίλης Τριανταφύλλου - Reply Share
Gimbal still is facing to the left
Luis Royo - Reply Share
When I put in the py setup.py install command, I get an error message. File
not found or something similar. I’ve tried redownloading and tried different versions of py and pyserial 3.5. Any advice?
Dji mini - Reply Share
Hi, this post from other forum helped me with this problem
Here are the steps to fix these issues:
Install setuptools: If setuptools is not installed, you can install it via pip, the Python package installer. Open your Command Prompt and run the following command: Copy this code
python -m pip install setuptools
Make sure that you have pip installed and that it is added to your system's PATH.
Check Python installation: The distutils module should be included with your Python installation. If it's missing, it suggests that there may be an issue with your Python installation. You might need to reinstall Python. Ensure that you download Python from the official Python website and install it, including the "Add Python to PATH" option during installation.
Paulius Zemaitis - Reply Share
Past 24 Hours: 4
Past 7 Days: 40
Past 30 Days: 190
All Time: 5,821
