How to Winterize a Sprinkler System
    1. How to Winterize a Sprinkler System, How to Winterize a Sprinkler System: step 1, image 1 of 2 How to Winterize a Sprinkler System, How to Winterize a Sprinkler System: step 1, image 2 of 2
      • Shut the water supply off to the irrigation system. (usually found in the utility room or basement)
      Ask FixBot
    2. How to Winterize a Sprinkler System: step 2, image 1 of 1
      • Obtain an air compressor. (you can rent one from the local Home Depot)
      Ask FixBot
    3. How to Winterize a Sprinkler System: step 3, image 1 of 3 How to Winterize a Sprinkler System: step 3, image 2 of 3 How to Winterize a Sprinkler System: step 3, image 3 of 3
      • Connect a hose to the compressor, and one to the water line (in basement).
      Ask FixBot
    4. How to Winterize a Sprinkler System: step 4, image 1 of 1
      • Turn the compressor on.
      Ask FixBot
    5. How to Winterize a Sprinkler System: step 5, image 1 of 1
      • Start manually turning on each station of the system one by one.
      Ask FixBot
    6. How to Winterize a Sprinkler System: step 6, image 1 of 1
      • Let the air blow the water out for about 2 minutes per station.
      Ask FixBot
    7. How to Winterize a Sprinkler System: step 7, image 1 of 3 How to Winterize a Sprinkler System: step 7, image 2 of 3 How to Winterize a Sprinkler System: step 7, image 3 of 3
      • Unplug the hose from the compressor and the water line.
      Ask FixBot
    8. How to Winterize a Sprinkler System: step 8, image 1 of 2 How to Winterize a Sprinkler System: step 8, image 2 of 2
      • Turn the air compressor off and then turn the sprinkler system off from the control panel outside.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 61
All Time: 1,231
